Chuck McCoy
- Jun 9, 2022
- California
- United States
- 2026 Minimum Spec: STARVIS 2 & HDR & Low Power Parking Mode
I’ve been testing / using the HK6 for a month now, and I’ve been posting tid bits in my A329S thread, but I haven’t been able to go full bore because my “newest” HK4 for contrast / comparison is 2 years old.
Ben @SafeDriveSolutions was was telling me a while back the “modern” HK4’s have been upgraded to reduce parasitic current draw when the camera is powered down, or not even connected.
So I’ve been holding off on doing any meaningful power consumption testing until I got my hands a “current production” HK4.
Well the wait is over, and I have a feeling this is going to get in depth real quick so I wanted to start a thread just for the HK6.
Q: What’s new / different about the HK6 compared to the HK4?
A: A lot. (keep reading)
Q: Are there any benefits of upgrading to HK6 for older models not capable of utilizing the new features?
A: Yes. (keep reading)
Q: What is the power consumption of the HK6 compared to HK4, and the new hardwire kit included with Viofo’s new dash cam battery pack (BP100)?
A: See post #11, and #12
Q: What is the Heat Signature difference between HK6, and HK4 measured with Thermal Imaging Camera?
A: TBA
Q: Can a single HK6 display vehicle system voltage to multiple supported dash cams installed in the same car?
A: Yes, I inadvertently connected the bluetooth signal to both of my A329S units, even though it was only plugged into one of them.
Q: How long does it take for the camera to recognize, and connect to the HK6 Bluetooth signal?
A: See post #13
Q: How does the HK6 make it easier to diagnose malfunctions like parking mode not working properly?
A: TBA
All these questions, and more will be answered soon enough.
If you have any questions, or would like a specific configuration tested / measured just leave them here, and I’ll work them into the schedule.
Now let’s look at some photos.
The first thing I noticed with HK6 was the increase in wire gauge (thickness) of both the 1 Meter end (power wires) that connects to the fuse box, and the 3 Meter end (USB Type-C Cable) that connects to the camera.
AWG Sizes;
20AWG: HK4 1 Meter End - RED (Battery +) / YELLOW (ACC) / BLACK (Ground)
18AWG: HK6 1 Meter End - RED (Battery +) / BLACK (Ground)
22AWG: HK6 1 Meter End - YELLOW (ACC)
Q: Why is the yellow wire on the HK6 smaller?
A: ACC / Ignition Signal, (does not carry current / amperage).
Outside Diameter;
4.1mm: HK4 1 Meter End (power wires)
4.6mm: HK6 1 Meter End (power wires)
AWG Sizes;
20AWG: HK4 3 Meter End (USB Type-C Cable) Power & Ground
24AWG: HK4 3 Meter End (USB Type-C Cable) ACC (ignition signal)
18AWG: HK6 3 Meter End - (USB Type-C Cable) Power & Ground
26AWG: HK6 3 Meter End - (USB Type-C Cable) ACC (ignition signal)
Outside Diameter;
4.2mm: HK4 3 Meter End (USB Type-C Cable)
4.7mm: HK6 3 Meter End (USB Type-C Cable)
The next thing I noticed was HK6 appears to be using 100% OFC Pure Copper wires.
I have always disliked CCA (copper clad aluminum) or Tinned Copper wires from the HK4.
This is a wonderful, and welcome upgrade, thank you Viofo!
HK4 Box & Date Code
HK6 Input / Output Connectors
BP100 Hardwire Kit Power Module
Next post should be power consumption measurements with A329S powered down, disconnected, and LPID, (low power impact detection).
A: TBA
A: See post #13
A: TBA
AWG Sizes;
Outside Diameter;
AWG Sizes;
Outside Diameter;
HK4 Box & Date Code
