rcg530
- Jan 23, 2021
- California
- BlackVue, Thinkware, VIOFO, Vantrue, Blueskysea, FineVu
Firstly, does this record in H.265 by default or do you have to press the MIC button? If the MIC button is not pressed I presume it records in H.264. There seems to be nothing in the downloaded manual about video codecs.
I am using the wm1 as a rear camera which is perfect. Its small and runs cool. I use the a119 mini for the front. I was going to switch out the wire and charger for the wm1 but its only ran to the outlet in my trunk so not that big of a deal to swap out later. I figured Id wait till the stock one dies. I can tell you for some reason an Anker Powerline III USB C to USB C Charger Cable 100W 2.0 will not power on either camera. Only reason I can think of is maybe the version 2.0 cable doesn't have some of the pins the camera requires. Stock charger for the mini I swapped out to a Motorola TurboPower Car Charger - 45W Dual Port USB-A and USB-C with stock wire for the mini and no issues. If I ever need to change the rear charger I just have to see if I can find a 10ft cable 3.1 or newer to see if it powers it on. The other addition I added to the wm1 because I constantly removing my cameras from my car was a magnetic adapter for usb c port. I always worry I will wear out the port and this one works perfectly www.amazon.com/dp/B0BYWP9Z7PMy WM1 review.
The camera was supplied by Viofo.
-Chuck
Did we compete?Yay! I finally beat @Karagandinez
I was just being silly. lolDid we compete?
Something I didn't notice.
It's just temporarily mounted with 3M Dual Lock.I'd be interested in seeing exactly what it looks like in there, and if it's discrete.
VIOFO WM1 - Improvement Wish List | WM1 | 6 | ||
VIOFO WM1 PURCHASE | WM1 | 3 | ||
VIOFO WM1 Test & Review RCG | WM1 | 18 | ||
VIOFO WM1 FIRMWARE | WM1 | 26 | ||
VIOFO WM1 | WM1 | 79 |
