Hack_man
I applaud your ability to communicate with a translator on a topic as technically complex as the dashcam. It can't be easy.Perhaps this is the translator's fault, but I didn't write anything for insults.
Even one manufacturer may not be able to make the cables to the additional cameras interchangeable. Because the rear cameras are different,One manufacturer can do it.
-snip-
It seems you've done research so I imagine you know already, but I'll just re-iterate the key points....But am I missing something? (assuming that I have no interest in an external SSD).
Upgraded Processor"missing something"
Even though both A329 and A229 use the STARVIS 2 sensors (if this wasn't the case, then it would be well worth the extra as this is a major aspect), the main difference is 60 FPS for the front camera and WIFI 6 (outside of external SSD); smaller addition is HDMI-out (I believe, I could be wrong that it's not on any previous models).
So for those who want the 60 FPS (it is much smoother, even if it's doesn't improve on static images) and/or Wifi 6 (it is rather handy as it *seems* to download at 40mb/s on my Pixel 7 Pro; which I'm not even sure connects at "Wifi 6"), then it's not something to be missed and is worth the extra.
IMHO, I took the advice that if you're already on an A229 Pro, you probably don't need to go out of your way and wallet to upgrade, but if you are coming from something different/inferior or no dashcam at all (my case), then it might be worth the extra to have the best start/beginning.
But if those aren't a priority for you or you consider those "basically the same results" [as the A229], or you think you might need more than 2 channels in the future, or don't like coaxial cord for the rear, or that rear CPL filter is just as different, then I would say you aren't "missing something"...
I really like that the A329 was running quite a bit cooler than the A229 PRO. Cooler = more reliable and less likely to shut down during hot parking days.It seems you've done research so I imagine you know already, but I'll just re-iterate the key points....
I think this was "Panzer Speak" for "Question everything, do your own research, confirm & verify, use your judgment, do what’s best for you." 😉Thanks for the clips, I've looked them over, and I'm not quite sure what point you were trying to make / which side you were on. You quoted 'am I missing something' as if I was missing something, but as far as I can see any situation where the A229 misses a number plate, the A329 also isn't legible... so they're the same.
Are you talking about when the external SSD is used?I really like that the A329 was running quite a bit cooler than the A229 PRO
That is exactly what happened to me! 😆I took your advice, and a $70 discount offer, and changed my order to an A329.
I probably won't ever put an ssd there, but 60fps and a better processor and bitrate are probably handy in the long run. I don't expect to ever change this camera for the life of the car so.
I found my A329 runs hotter than the A229 Pro both in 2-CH rear configuration in every heat test I performed.I remember a data point, I think Vortex Radar collected with his nifty thermal imaging equipment. I'll see if I can find it.
He made this statement: Cooling: Viofo's improved the cooling here and so the A329 runs cooler than the A229 Pro. I found the temperature variances to be greater after 1 hour of recording compared to 8 hours of recording, but either way I think the updated A329 will be a better option for people driving in hot climates.
He was not testing with the external SSD (from what I can tell) and measured up to about a 10C difference. Video starts at correct timestamp below.
It would be nice to understand the discrepancy between Vortex vs Panzer heat testing.
In the Vortex video it doesn't look like an External SSD was connected.
Both tests show a similar location of the hotspot but Vortex is 9 C hotter on the A229 Pro vs Panzer 11 C cooler in normal recording mode.
Yeah I didn't do any testing with an SSD connected. In theory we should all be able to reproduce this test and get the same results. I'm not sure why we're seeing different results.
The microSD card may make a big difference to what is seen on the side view, some cards generate a lot more heat than others, and that heat is seen on the image.On the main board the two components that produce the greatest thermal signature are the Novatec and the controller for the microSD.
That is very interesting that some cards generate more heat than others. With that kind of variable it's really hard to get consistent thermal readings. I imagine you are referring to slow cards with more dead spots in the magnetic media.The microSD card may make a big difference to what is seen on the side view, some cards generate a lot more heat than others, and that heat is seen on the image.
Also camera settings can make a significant difference, especially bitrate for card slot temperature.
I think the heat generated depends on the technology used, some are more power efficient than others, it tends to be the faster, more expensive cards that run cooler. It is quite likely that both Vortex and Panzer were using Viofo cards, but even card capacity can affect the heat generated since a different technology might be used for the larger capacity cards.That is very interesting that some cards generate more heat than others. With that kind of variable it's really hard to get consistent thermal readings. I imagine you are referring to slow cards with more dead spots in the magnetic media.
