Onetenner
- Oct 26, 2025
- Ubique
- United Kingdom
- Vueroid D40-Q2
I'm part-way through investigating the cause of loss of DAB band III reception on some multiplexes, it's not clear when this issue started, but it only affects 'some' multiplexes - these are not particularly strong signals anyway, but drop-outs have become more frequent & noticeable, for example, you can drive down a residential street and the signal will drop when you pass a house but come back as you pass the gap between houses. It's likely that all multiplexes are attenuated, but not to the point of dropping the signal as some are stronger than others - this is unfortunately due to how much the media companies are willing to pay the infrastructure operators.
The reason I'm not clear as to when it started and what, if anything, changed is it only affects the stations the Mrs. listens to..... and she's not in the car every day or even every week.
Yes, there are workarounds, such as streaming via phone etc. but the point is, it used to be OK.
Diagnosis of DAB interference / signal attenuation is notoriously difficult, so far I've:-
Carried out continuity & 'phantom power' checks of co-ax cables
Replaced DAB band III antenna amplifier
Replaced DAB band L antenna & amplifier
Replaced DAB receiver module
None of which caused any noticeable difference, it's worth mentioning that any fault in the band L amplifier or antenna will set a DTC, whereas only the amplifier is monitored for the band III antenna (and I'm aware the UK uses little to none of the band L spectrum for DAB broadcast). So far, it hasn't cost me anything other than time as I'm fortunate enough to have a ready supply of donor vehicles at work to substitute parts from (one at a time), what has made a difference - well reverted DAB reception on the affected multiplexes back to 'normal' is disconnecting the rear camera at the main unit.
My next task is to use a RF spectrum analyser to determine if, and where from (i.e. camera or cable) the 'noise' is coming from.
The image below shows the setup, of the two flat antennas, the one on the right 'B' is the DAB band III & FM antenna, the other is AM/FM. The amplifier is mounted adjacent on a metal ground plane, I've checked the ground connection and resistance measurement from the ground plane to battery -ve terminal is 0.06 Ohms. The DAB band L antenna is in the roof 'fin' along with GPS and GSM antennas.
The two badly drawn lines represent cable routes, the green one is the camera cable, the dashed section shows where it passes through an existing wiring grommet into the interior of the car, the blue line shows the existing co-ax antenna cables, these are RG174 with braid & foil shielding. Total parallel distance of the camera & antenna cables is ~700mm including where they pass through the flexible tube between liftgate & car body.
So, has anyone else experienced this? I have previously diagnosed similar on Audi & Mercedes-Benz vehicles where the DAB antennas are printed on the rear screen (not the case in my scenario) and the rear camera completely knocked out DAB reception, mind, the camera's were 'bargain basement' and the cables even cheaper...
Assuming I can definitively identify unwanted electrical noise from the cable or camera, although the camera is probably 150mm away from the antenna and 200mm from the ground plane, I'm considering applying some copper tape to the outside of the cable and connecting to a suitable ground inside the car. Although the AM/FM co-ax cables run to the front of the car, the DAB co-ax only run a short distance (about 1.4m) inside the car to the DAB receiver module where the output is transmitted to the amplifier on the MOST (optical fibre) ring so I'm sure the signal attenuation is occurring within the liftgate area.
