Hi
My set (a510 +UP 04 + rear camera + powerbank energywell p6 ulutra to protect car baterry) operates a lottery. It cannot accidentally wake up the Dash cam. It works the same like yours. I use the USB c cable from the kit. According to the 70mai, the angled tip must be plugged into the module. I tried to rotate the USB terminals in the camera and the module. It didn't help. It often helps to turn the camera off by pressing the button and turn on again. Sometimes even that doesn't help. The problem is solved only by restoring dashcam to factory settings (There are days when even that doesn't help). Often, after starting the car and charging the power bank (after it has discharged), the camera does not see UP04. Sometimes helps to turn the camera off by pressing the button and turn on again, (but not always). I don't understand why the camera doesn't connect to the module immediately after regaining power. The strangest thing is that the parking mode works (dash cam informs you when it is turned on, tehn only battery protection is not visible in the settings).
The Polish support of 70mai does not respond to e-mails, on their YouTube channel they recommended e-mail contact (and still no response - a month!!!)
Official support recommended that I downgrade the UP04 firmware - but the instructions do not work (Incomplete manual how to do it)
My Firmware
A510 Dash Cam 1.6.74ww (There is no newer software by application)
4G Module (up 04) 1.3.64.ww (There is no newer software by application)
It doesn't seem like an isolated problem (I find one person with this problem on this forum). It seems to me that the problem itself lies in the A510 (software or hardware) or the USB cable.
Polish 70mai support ignored me, Official support send me to a repair service under warranty (because downgrade UP04 - when I wrote that the instructions were incomplete and did not work
- SIC!). And this will probably end with a refund of money and not a solution to the problem.
Currently, I am left with a set that is not suitable for parking protection, no support 70mai.
I need help (not refund).
New future for A510
- Add the ability to online download routes traveled - only GPS route
- Information about battery power as in higher models.
Best Regards
