D
Deleted member 24437
Guest
It is from Ardyleo!
I downloaded the XIMODE 2.1 and I found the script for delete thm files, thank you very much for your help!It is from Ardyleo!
You're very welcome,Ciao!I downloaded the XIMODE 2.1 and I found the script for delete thm files, thank you very much for your help!
Hey,
I have the problem with this firmware that sometimes it just records a few seconds. And when my SD card is half full it is not recording anymore and just freezing. Anyone else with this issue?
SD-Card: SanDisk Ultra MicroSD XC I 64GB
Is there anywhere a firmware without thm files and about 25Mbit?
Hey mighty,
thank you for your fast response. I took the firmware from the first page: 1.2.13 35Mbit
My SD card is able to write 15MB/s. I thought this is sufficient but now I will try to get a U3 card and test again.
Is there an easy way to reduce this firmware to maybe 25 Mbit, but to have all the other adjustements? For me, this firmware looks also more sharpen.
regards
What did you use, the 1st or the 2nd link? I have Z25L, too. I don't know which one to use.Thanks, this custom firmware works on my Z25L with 35Mbit. Somehow the autoexec scripts for high bitrate won't work on my Z25L (with Z23 firmware).
