Xiaomi Yi RAW/DNG Workflow for Mac OS X
nurtext
Germany
Hi all,
I've set up a small, dedicated package for doing a RAW/DNG workflow on Mac OS X. The package contains a Mac version of raw2dng (Wine-based, standalone), ExifTool for correcting black/white levels, an Automator droplet for batch conversion and a small install guide/tutorial.
It is 255 MB in size and can be downloaded here:
https://www.dropbox.com/s/kxyz0zht7cc17eb/Xiaomi Yi RAW-Workflow.zip?dl=0
Let me know what you think.
Cheers,
Cedric
works perfect on Yosemite 10.10.5...many thanks!
I wish this worked... I have tried MANY methods of both taking and converting and had NO success.
I am running OS X 10.11 El Capitan And Prior 10.10 Yosemite.
I have used the following to capture RAW:
1) t cal -raw 8 1 0
2)t cal -raw 4 1 0
3)t app test debug_dump 14
I have tried RAW2DNG in both Mac and Windows to no avail despite both having the Xiaomi Yi listed in them
All I get is "error: unsupported format"
I have been over every forum.... no answers to this yet.
This is a RAW and the exif jpeg for anyone to try.
https://www.dropbox.com/s/vleqcdxwlgfp9kt/YDXJ0001.jpg?dl=0
https://www.dropbox.com/s/fmvrm6dyqwtr8qi/YDXJ0001.RAW?dl=0
Here is a second set that for some reason uses 2 jpegs for exif but has same error
https://www.dropbox.com/sh/8ycdpt4um1c7dzw/AACoFHum0vKNDINk1kuNu7Dwa?dl=0
Good Luck
Xiaomi Yi - YDXJ01XY
Firmware Version - 1.2.13
Model - YDXJ_v22
Hi, I've tried it and it works perfectly. It is very simple to use and works with no problem. The dng files can be opened with lightroom and just a small correction in temperature is needed.
Next, using the camera profile made by schnurbi, the final result in lightroom is perfect. In order to use this camera profile, the file "Xiaomi Yi.lcp" needs to be located in the path:
/Users/home$/Library/Application Support/Adobe/CameraRaw/LensProfiles/1.0/Downloaded/Xiaomi/Xiaomi YI.lcp
You have to use your own home$ name, and probably create two folders, Downloaded and Xiaomi. Finally copy the lens profile "Xiaomi Yi.lcp" inside the Xiaomi folder.
Nurtext, thanks very much for your package.
Thanks! So it works for the single photos I took, but not RAW photos from time-lapse. Anyone else faces the same problem?
1) t cal -raw 8 1 0
2)t cal -raw 4 1 0
Good Luck
Model - YDXJ_v22
I have the exact same problem, raw2dng days "unsupported format"
Hi all,
Cheers,
Cedric
Hello Cedric, the dropbox link is down, could you resubmit it?
