kaanklky
Hello everyone,
I'm using yi while I'm cruising with my motorcycle as daily. I didn't understand why that happened (spike?) to my yi because I didn't change anything on it. Yi can't record video smoothly, I update the firmware from this post but it didn't change anything. I'm also posting media info.
WHOPS: I noticed something when I tried to add video to my post; video was lower fps and has bounces between fpses(spike?). But it is looking fine when I upload it to youtube.
Thanks for help.
Code:
General
Complete name : YDXJ0141.mp4
Format : MPEG-4
Format profile : JVT
Codec ID : avc1
File size : 19.2 MiB
Duration : 4s 555ms
Overall bit rate mode : Variable
Overall bit rate : 35.4 Mbps
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=8
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 4s 555ms
Bit rate mode : Variable
Bit rate : 35.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 119.880 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.317
Stream size : 19.2 MiB (100%)
Color range : Full
Thanks for help.
