I have a couple of questions as a new yi user. I've successfully installed the alex-version of the script and changed settings through telnet om my phone, including higher bitrate of video.
What happens if I change resolution settings in the Yi app, will the bitrate still remain if I change back to 1080/60 at 35 mbit which is my setting in xyc?
By the way, any recommended NR and sharpness setting?
Thank's for developing this!
please, i would like to get an answer to this as well,My question would be, that i see you added yi movie, which is a set of res+bitrate+nr and sharpness tweak, so if we activate yi movie mode we are not advised to adjust those settings from the script?
I can´t open the script... I write /tmp/fuse_d/xyc.sh and always get " line 4: sintax error : unexpected newline".
With the old version of ml72 had no problem....
Guess that you downloaded from GitHub by Save As...
Download by ZIP button on the right, syntax error here means xyc.sh file is wrong, if it continues open your xyc.sh file that you upload to camera with notepad and compare with one from GitHub ZIP version
This should helpi cant even get connected with telnet client on either android or ios device, maybe som screeenshots on filenames and exactly how to connect would be a good idea?
