Hi, would it be ok if i ask some questions, i want to try this file, but would like to understand better, i put some question in () in red so you can see which one they are..i know im probably being a bit blind, but just want to be sure
#video script by gente for 1.2.13 firmware
#loudness boot buzzer
t pwm 1 set_level 70
(what is this? adjusts volume?)
#2304x1296 30 fps 45 mbps
#writeb 0xC06CC426 0x02
(what is this? do we need to remove the # on all 3 lines or just 2 for this line above to run?)
#writew 0xC05C1EB2 0x4234
#1920x1080 60 fps 45 mbps
#writeb 0xC06CC426 0x03
#writew 0xC05C1EE2 0x4234
#1920x1080 45 fps 45 mbps
#writeb 0xC06CC426 0x04
#writew 0xC05C1F12 0x4234
#setting vibrance and saturation
t ia2 -adj ev 10 0 70 0 0 150 0
(this will run auto if not add #? what is it? )
#shadow/highlight clipping adjustments
(what does this do? )
t ia2 -adj l_expo 163
t ia2 -adj autoknee 150
#set gamma level
t ia2 -adj gamma 200
#enable 1/13/14/34/38 scene modes: auto/landscape/portrait/through_glass/car_DV
(can you see when different mode is enable in app? )
t cal -sc 13
#noise reduction 0:no reduction(noisy but sharper)/16383:full noise reduction(no noise but less sharp)
(what is standard setting to know how to adjust?)
t ia2 -adj tidx -1 500 -1
(is 500 the only number you change? 0-16383?)
#fix ae/awb/af/adj 0
![Eek! :o :o](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f631.png)
n 1
ff
t ia2 -3a 1 1 0 1
(are these modified? your best ones, or standard?)
#Set JPEG quality to 100%
t cal -jqlt 100
(what is standard?)
#vignettenkorrektur abschalten/v:video mode,s: still mode/enable 0:disable,1:enable
(can you explain this one please?)
#t ia2 -vnc v 0
#enable raw+jpeg stills
#t app test debug_dump 14
#set file size to 4GB
(do we enable all 3 line below to get card to write 4gb of data? )
#sleep 3
#writew 0xC03A8520 0x2004
#sleep 1
#sd test script by nutsey
cardmgr d info > d:\cardinfo.txt
(what is this one ?)
sleep 1
(what is this?)
t app lowbatt 100 10000000
(what is this?)
#ready beep
t pwm 1 enable
sleep 1
t pwm 1 disable
