EGS
- Aug 29, 2019
- Texas
- Viofo A129 Pro Duo, A129 Plus (eMMC), T130, 70mai A800s
My suggestion is to put the heat sink in place and once it is well seated, mix a bit of epoxy and put a tiny drop on each corner. Once it sets it won't go anywhere but will be fairly easy to remove if nece
i have pulled those off as they restrict the air flow even tough you can blow air trough themAs you might have noticed there are some kind of filter on the cooling vents on the side of the case, it is so fine masked you will need a fan to get any air to pass thru it, so i have removed it in my T3
