Ok well short of finding a copper sheet, this camera is nonsense. What Zenfox now did was disable the Interior Camera First, when the camera overheats. So the Front + Rear record. Not really a solution....Just some bandaid.
I guess the only solution is to replicate what @EGS did. I could glue down the heatsink, but I DOUBT that'll change my results. Thermal paste is on there enough to make sure that heatsink doesn't move a muscle. I may just try glue just to see, but I give that zero chance of working
What I truly suspect, is that @EGS's option covers the thermal sensor and shields it. Thereby prolonging the camera before it cuts off.
45 Minutes in the hot sun and the camera was Front + Rear only when I came out to check.
I think you are being unrealistic, 32C outside is going to be a problem with that processor. If you want it to work in parking mode with all three cameras recording in a locked car with the windows closed then you will need to add a fan, and maybe an extractor fan for the car too!We shall see what happens.... Sun still out and registers 32C (90) outside and 40C (104) with sun beating on car.
I find that highly unlikely, everything under the EMI shield is going to get hot!I believe@EGS solution works because it covers the thermal sensor.
Notes:
- EGS's copper spacer has twice the surface area of yours, that will make some difference.
- EGS's also has a temperature limit, I suspect his doesn't manage much more heat than yours.
- You are comparing it with an A129 Duo with a lesser processor and lower cooling requirements, EGS is comparing with an A129 Pro with the same processor.
- I'm surprised your heatsink doesn't fall off when the paste warms up and becomes less sticky! You really should secure it.
Wow, that is bad. Never thought it could get that hot. Something has to be wrong with that particular camera.Well here's one for the record books. It appears that the copper shim drew away so much heat from the SOC to the Heatsink, that the plastic housing on my camera is warped. I took things down to do what I hoped was a second layer of Copper under the Heatsink. Brought Camera inside to get work. Well not surprising, when I opened camera to try to make said adjustment, the heatsink was flaming hot . And that heat appears to have been sufficient to melt and reshaped the housing. I can no longer close the case properly or mount camera on my windshield.
Vaya con Dios (Go With God) 2nd camera. So =) my trials are done. FYI: The Viofo never missed a beat.
I'm giving this camera zero stars. Firmware didn't resolve squat and the quality of this thing is very questionable at best.
I'm melting......(Said the Wicked Witch)
Here's what I was attempting and when I went to close up the housing, I noticed things didn't sit right anymore.
Or could it be that they indeed raised the temperature cutoff threshold in the new firmware and now it is too much? I don't know what to tell you.
At least that shows that the Heatsink did a good job of extracting the heat away from the SOC after your mod, but too much for the plastic to handle it now.
It was a very long day for me doing some work outside and was reading here occasionally in my breaks I was taking, but not enough time for me to jump in to participate. I haven't even flashed the fw to the camera yet. Will do that sometime tomorrow hopefully.
I know I won't be using my cameras in parking mode as in my situation it is not so much needed but still wonder for those that really need the feature.
It is so that the camera can be mounted behind the mirror with the interior camera looking over the top of the mirror and the front camera still able to see under the dotted area/through the area swept by the wipers. Doesn't work like that in all cars, but when it does it is a neat solution.@Zenfox_Official
Interesting design.
I haven't read all the posts but the front facing lens pretty low.
Is that to reduce heat or to have extra space in the unit for hardware?
It no longer fits because you have added 0.8mm of height in the form of copper shims, take them out and it will fit again!Here's what I was attempting and when I went to close up the housing, I noticed things didn't sit right anymore.
Maybe
The one that seem to hold the GPS antenna in place, i have some stiff foam wedged in there,,,,,, not a wide piece of course but just a little to exert some pressure down on the heat sink.
My heat dink will not come off the EMI shield as it is soldered, but the EMI shield i have just soldered in the 1 place it was from the factory, so to make sure thermal bridge is good i made a little wedge.
My camera have not smelled of melting plastic, but i have noticed it is already pretty loose on the mount, some PVA foam pads like other brands supply will be needed soon.
Yes took off EMI shield, removed gap filler thermal pad, cut / trimmed EMI shield so it could get down in contact with SOC, used thermal compound like you use between SOC and EMI shield and between EMI shield and heat sink on top.
And i trimmed the lip off the heat sink as it would otherwise rest on the taller connector for the front camera.
Used my Dremel clone to lower EMI shield sides to 1.5 mm so it would be able to get down and touch the SOC that in my camera are 1.8 mm above the PCB.
In order to do that i also have to cut away a little of the EMI shield at the memory card slot and the two camera ribbon connectors.
So mine may be the most modified T3 of them all
I also have not connected the EMI tape on the two camera ribbon cables, i see no AV disturbance, but there might be on audio as i have cut the MIC wires and not yet put those back together.
