70mai A500s Pro-Plus-Firmware Mismatch
JCHAI
Selangor
Malaysia
Hi, I need guidance and assistance on the firmware mismatch problem which I upgraded the latest version and resulting the dashcam shut down and not functioning now.....😢
What is your A500s version? Chinese or international? If you have the Chinese version, then the latest international firmware available to you is 1.0.17ww:
The following updates will result in a FIRMWARE MISMATCH error
Hello Lisabon, I have problem with CN A500s Dash cam A500s Pro Plus mismatch firmware. Please give the permission to google drive.
Thank you
Thank you for the permission, Lisabon! However, the Dashcam still do not push through with the flashing and directly goes to Firmware Mismatch screen 🙁
Same
May i request a link firmware for my 70mai a500-s to fix firmware mismatch issue please…
Thanks in advance
I got the same problem bro. I have tried the guides about, but it didn't work. I hope someone can provide better solution.
Hi. Could you please share, what's the thing you have done in order to fix this kind of issue.
I just followed this steps…
- Remove every file inside your SD card after pluging it in your computer so that it is completely blank
- try to find and download the file "FW96580A.bin" in google… drag it inside your SD card so that the only thing in the SD card is this bin file
- BEFORE Powering on your dashcam, plug in your sd card inside the dashcam.
- Now power it on
- You will see blue light flashing, that is completely normal just wait a little
- When it opens up, it will walk you through the steps where you can choose English etc
- It will ask you to format sd card, press the format button and you are ready to go
I just followed those steps..
- Now power it on
Hi bro. This is exactly what I have done. But it doesn't work. The firmware mismatched istill showing.
hi can you teach me how to do.i just get this problem and cam cannot working now
- Now power it on
i try but still cannot .
You need to use this firmware.:
