Bill Watson
- Nov 20, 2015
Hi All, first time posting.
I recently have started toying with firmware for my 0805 to see if I could get the menu option to rotate the display as the pdf for the 0805 clearly states "2.5.23 Setting Display Rotation".
I have loaded multiple firmware versions found here and there and no luck with that option. I have tried original factory to the latest one posted by user McGee dated October 10 by Eprance.
The only reason I need this option is I have mine mounted on a sticky pad on dashboard which I use in multiple vehicles and it is mounted with units mount on bottom. It works fine with the display rotated correctly but menus are upside down and also records upside down. I realize video can be edited to flip but what a pain in the butt and degrades quality when flipped and takes a while as I don't have a full video editing suite and don't want to either. I would prefer to empty SD card once a month and archive as is.
Anyone have working firmware for 0805 with one card and GPS that has the option that will flip menus as well as display and record upright on playback on PC?
Thanks again.
Thanks again.
