Gramercy
- Jan 24, 2018
- Netherlands
same here ! No goodAfter installing 1.007 the gain on the front camera is completely maxed out. The recordings are washed out to an extent that it's impossible to see anything at all. I tried changing the brightness settings to 1, and I rebooted the camera. No luck. The rear camera is fine.
same here ! Not good ,After installing 1.007 the gain on the front camera is completely maxed out. The recordings are washed out to an extent that it's impossible to see anything at all. I tried changing the brightness settings to 1, and I rebooted the camera. No luck. The rear camera is fine.
I wonder if they test their firmware on toasters first.![]()
My recuring problem is the “incorrect Wi-fi password” message when connecting to the camera. Password is correct and only a system restart will sort it. Problem happens every third or forth time I connect.
Can confirm this.
It’s a shame, took me 5 minutes to find that Pittasoft has done it again. Front cam is a total failure after update to fw v1.007.
WIFI/Live View, Cloud/Live View and recorded files from front camera is totally useless.
Rear cam is okay.
Have sent email to support at Pittasoft with a couple of screenshots of the mess, will be interesting to read their excuses this time.
I have of course downgraded to v1.005 and everything is just fine again.
View attachment 38821 View attachment 38822
had you changed the password from the default setting?
Hi Joklin.
I have only ever used the default password. Do you think it’s worth changing it or even removing it?
Appreciate your help.
Dan.
