The way the cf100 goes into parking mode is there can't be any motion in the video frame (front and rear) for about 5 minutes, and there can't be any vibration or anything that would set off the g sensor. Then it will announce "parking mode is getting started"
I have the front parking mode led disabled, but the rear LEDs for record and GPS always stay on solid.
Good to hear it records front and rear in separate files, but that front bitrate sound REALLY low. What resolution and sharpness do you have it set to?
Installed. Took me 2 hours. Routing the cable to the rear above the headliner took the most time. I have a Rav4 and it's very similar to your Sienna. Thank you for posting your instruction which helped a lot. I didn't run any wire behind the A pillar. I stole the power from the sunroof.
Front cam is set to 1080 and default brightness, and rear to 720, default brightness but there is an option for tinting in the program which is set to high. No sharpness settings at all in the app/program.
Update after installing:
- The low bitrate really causing blocky videos. But I was driving on local streets with lot of trees, buildings and shadows. Will try on highway and the city this evening and late night.
- After I cut the cable for hard wiring, I found 3 small wires inside, red, yellow and black. The red and yellow are tied together to the positive of the cigi lighter plug. The color code is so obvious, but I still test them with a power probe. I connected the red wire to constant, yellow to acc and black to ground. Parking mode kicks in within the set time (set in app) after the key turned to off. Driving mode starts as soon as the key is turned to on.
- The power, gps etc LED's don't turn off in parking mode. Front security LED and a little blue LED on the rear camera can be disabled.
- In parking mode with motion detection, front and rear operate separately. If the front detects motion, only the front will record. Same to the rear.
- The G sensor is way too sensitive. I had it set to 2 and it alerted me for event recording when I ran over a little bump. Set to 1 now and see how it goes. Otherwise I may have to set it manually which is possible in the app.
Will post some video clips after some real live driving.
