D
Deleted member 2298
Guest
Looking for a dash cam that also has a mode to record 30-45 minutes continuous video with no breaks/cuts. Does such a thing exist? If so, any recommendations?
dan7u said:Oh. I was looking for something that could double as a gopro style camera for trackdays. 30 minutes should be enough. Any cameras able to do this?
dan7u said:When you stitch the video back together, isnt there still a tiny gap between segments?
dan7u said:Any recommendations on cameras that have gapless recordings after stitched back together?
How about cameras that can do this amount of time continuously?
thanks.
jokiin said:dan7u said:Any recommendations on cameras that have gapless recordings after stitched back together?
thanks.
any Ambarella chipset based camera can do gapless recording
Zoran chipsets quite often have a gap
Novatek have the opposite problem and quite often have a 1 second overlap
for continuous use recording time will be limited to file size of 4gb, how much recording that is depends on the bitrate offered, a lower bitrate will give you more time but a lower quality end result, higher bitrate will offer greater quality but you'll hit the file size limit faster, 15Mbit/sec will get you around 35 to 40 mins, lower birates will offer longer record times
niko said:I agree, for example all those dash cams i tested running on NT96650 they overlap 0.8-1.0 sec and this sucks ! It is very hard later on to "glue" all files at correct position to get smooth video.
Zoran Coach 12 that Panorama2 uses perfomd the best way with no gaps, but it looks like all about how good tuning has firmware.
4gb file limitations haven't changedAny cameras on the market offering this now?
Again recommending DoD LS430W - DoD LS330W They provide fast g force data as well. The only issue you need to watch with those, is that they will be a tiny bit out of focus when your in car temp goes over 30C (well really over 40C). This can be a problem in some race cars to say the least.Any recommendations on cameras that have gapless recordings after stitched back together?
thanks.
