- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
External hard drive support will come
So, can this be bought anywhere yet?
you can't extend the lens very far at all without interference becoming an issue, to get greater distance there is a transmit and receive chip required each end, you'll see solutions very shortly where the lens can be several meters from recorder and still deliver 1080p resolution without a problem, a couple of models will release over the next few months
I mistakenly thought it was more about using wires that were to small and needing shielding around the cable. Things are always more complicated than they look from the outside.
What's the difference of having 4 separate full size cam? Just the controller, power and one common SD card?
Price is not bad for around $250, you get four 1080p dashcams.
Okay worse than I thought.4 cards not 1, or 8 cards if you want to use the internal and external slots, they're awkward cameras that take up more room than it looks
then you just need to rig up all the emergency/lock buttons to one big red button on your dashboard. i recommend using this button:Okay worse than I thought.
Let's see, 4 G1WH for around $160 and that'll be 1080p 4-channel.
That's actually never a problem... with a 32gb card on each, I have almost a week worth of data to go back and save if I need to.then you just need to rig up all the emergency/lock buttons to one big red button on your dashboard.
When there is normal traffic, it takes around 35 minutes for 23 miles so 32gb will have almost all workday (5 day) videos.32gb @ 1080p usually only gives about 5 hours. must be nice to have such a short commute.
