Chuck McCoy
- Jun 9, 2022
- California
- United States
- 2026 Minimum Spec: STARVIS 2 & HDR & Low Power Parking Mode
In this post I will perform the fourth charge cycle with hardwire cable.
This time I will increase the connected loads to 15 Watts.
1st Load: A229 Duo 4.6 Watts connected to Hardwire Output Cable
2nd Load: DROK load tester adjusted to 10.4 Watts connected to USB Output
Specifications for charge time:
Hardwire Cable: 60 Minutes (up to 11 Amps)
Cigarette Lighter Cable: 90 minutes (up to 7 Amps)
0% Start
25% 18 Minutes
50% 17 Minutes
75% 17 Minutes
100% 17 Minutes
Total: 1 Hour 9 Minutes
Previously it only took 58 minutes to charge the pack with no loads attached.
With a 15 Watt load connected it added 9 minutes to the charge cycle.
The maximum amperage draw was 8.6 Amps @ 14.2 Volts (123 Watts).
Same high pitched whine during charging.
0% Start
25% 18 Minutes
50% 17 Minutes
75% 17 Minutes
100% 17 Minutes
