Mtz
- Nov 15, 2012
- Nice place
- Romania
- Viofo A329T (the best dashcam in the world!)
But still no room for USB connector.
enjoy,
Mtz
enjoy,
Mtz
I wonder how much room the case really has, wether it would be possible to hack apart the usb connector and make it fit into that case somehow, no matter the presentation of the cable.Mtz said:Forget the connector idea and is already a long one. More than that, the micro USB connector is not a standard format so if you are planning to play with the cables prepare to buy at least one for spare.
From my #18 experience they have 3 cables:
- one USB Cable just for charging which is long and contain only 2 wires for charging
- one USB Cable for data transfer, WebCam and charging
- one USB AV Cable for AV Out and charging
I ordered the USB AV Cable as spare because seems to be the most complicated and for $4 I want to be in the safe area.
enjoy,
Mtz
And is it safe enough that they won't short, pop out etc?Mtz said:As I already said, the best is to use 2 tiny wires. For 5V we don't need more. That wires can be attached over the actual USB pins and took out near through the reset hole. You can even enlarge just a little that hole if you don't have such tiny wires.
Here is an example of my old #18 720p camera and the pictures is just to show that I can insert 2 wires in the hole.
enjoy,
Mtz
Not going to change my ways 😉Mtz said:PS: I hope you will not respond to me again with another quote. I just don't like them when are from the previous post. 😎
Mtz said:The difference is not only in the chipset, but in the lens, firmware, if cameras have bugs.
Because #26 is a small camera not dedicated only for driving it have a small lens compared to its sister the DR32. Look for some DR32 videos because that camera have the same chipset, just the lens differ and in this way you can compare some Ambarella videos and some iCatch videos.
enjoy,
Mtz
