I've just got an A118C from Amazon here in the UK. It seems a little buggy. It records video and audio fine at first but later clips all share the same audio. It seems to get stuck and the video moves on but the audio stays the same. Also, haven't had much luck with the G sensor, it's way too sensitive. Even a small bump in the road sets it off and then all following recordings are protected. I switched the G sensor off.
Anyways, I can live with the above but the biggest problem is the video quality and in particular the exposure handling.
I left the EV setting and HDR at factory settings but some of the footage is really dark. I've added a couple of screenshots to show the issue. Both taken on the same day in similar conditions.
Is that what I should expect from the cam. Would a Mobius produce better images in the same conditions?
