Also, the camera died after 1 week. When I received the camera from the seller, I checked it by connecting it to a computer. It worked without problems, video on a micro SD card was recorded. I tested it for several hours and put it back in the box.
After a week, I again got the camera out of the box and reconnected it to the computer. I did not see the backlighting of the buttons or the display, but instead of the logical drive on the computer, an unknown device NT96660 appeared in the device list. When I press the power button, the NT96660 device disappears in the device list, pressing the button again will reappear. After many times the switch on-off cycles, the camera can normally turn on. After this switch-on, the recorder operates before the power is turned off. But these are normal turn on, if there are no micro SD card in it. With micro SD card not never been able to turn it on.
What I checked
1. different power cables: two native cables, from the CDROM drive
2. power supply: USB 3.0 computer, charging from the ipad.
3. swapping the micro SD card
4. Check the power supply through the connection jack of the GPS. Power 5 and 3.3 volts are available.
What happened?
What I checked
What happened?
