adisan
- Jun 9, 2017
- Romania
Viofo Romania are part of the beta test team and are a trusted source, will be an official version if it has come via them
New version: V3.3
1. New: Added Parking Mode (at user request)
2. New: protection against erasure and previous video if you press the Emergency button in the first 15 seconds of the current video
3. Enhanced: another sound when pressing the snapshot button (snapshot)
4. Enhanced: when the screen is off the REC and Audio buttons act directly, it does not take two button presses
5. Enhanced: Complete removal of GPS data from the video connector when the GPS function is deactivated
6. Remove: unwanted screen ignition in Motion Detection mode
7. Remove: Appearance XXXX at the bottom of the screen in very rare cases
https://drive.google.com/file/d/0B5w3cg7r2yeeSTYxY2JWcE1wOGc/view
I have WDR, lane departure, and forward collision turned off. Are those the recommended settings?
how do you get to the menu on that dashcam?That's one of my favorite features of my wife's Blacksys CF-100 - you can't ever stop recording by pressing a button. the only way to stop recording on that camera is to unplug the power cord.
In Parking Mode, you need a slight camera movement, such as happens when a person gets into the car, to trigger the G-sensor to switch from Time-lapse recording back to Normal recording.my 5c: I noticed it's not always switch to Normal mode from 10 hours of parking mode, just keeps recording 5fps.
Thats what happened - I got into a car in the morning - still 5fps, got to work (about 15km drive ) - still 5fpsIn Parking Mode, you need a slight camera movement, such as happens when a person gets into the car, to trigger the G-sensor to switch from Time-lapse recording back to Normal recording.
The only reasons I could think of for @admin1 's A119 behavior in Parking Mode was that either the menu settings were incorrect or the G-sensor was not working properly to switch the A119 back out of Time-lapse recording.Thats what happened - I got into a car in the morning - still 5fps, got to work (about 15km drive ) - still 5fps
I will stick to 2.2 if you want better image quality
Don't know about firmware V3.3, but in firmware V3.1 Parking Mode, my experience is that G-sensor (slight car/camera movement) triggers do cause the A119 to resume Normal recording, i.e., recording at that resolution and fps set in the Resolution menu setting. If your concern is that the A119 will stop recording when no G-sensor or Motion Detection triggers are sensed for 1.5 minutes instead of continuously recording in Time-lapse until the next G-sensor trigger, then your concern is valid. However, if one is concerned about power consumption, continuous Time-lapse recording with no G-sensor or Motion Detection activity is not the better option.As I said,if the Parking Mode does not have the possibility to record continuously at X fps until triggered by G sensor or movement detection,the new 3.3 has no improvement...
By the look of the change log, it looks like V3.1 all over again except for #7 about the XXXX box issue. Maybe V3.1 with a few changes, no?anyone know what 3.1 and 3.3 differents is?
