A119 Mini 2 - HDR schedule
alphamylan
Hi , I have just received my A119 Mini 2
I see in the settings there is the option to schedule HDR on (ie for HDR to automatically turn on at night)
However, with HDR the FPS is only 30.
Is there any way to set the following schedule?
Daytime , 2560x1440 60FPS , HDR off
Night time, 2560x1440 30FPS, HDR on
You will get better image quality with 30fps for the same bitrate, we recommend using 30fps all the time. Unless you are on the race track, in which case you should turn HDR on and off manually.
Set these settings:
2560x1440 60FPS
HDR = 20:00 on/6:00 off
Watch what will happen.
In the Mini topic, there was information that on some of the firmware they made a return to 60FPS after turning off HDR.
But 60FPS should be in the settings with HDR off.
Perhaps on the Mini 2 this is all already in the firmware.
Although, as you wrote above, you are unlikely to see improvements from 60fps.
You can set in the Auto HDR Time to decide the time when the HDR should be on. And the resolution will drop from 60fps to 30 fps when the HDR is on and back to 60fps when the HDR is off automatically.
It is wired to a bad circuit or the third party device is faulty.
We keep asking the OP to perform some basic diagnostics but he keeps posting 'I have to unplug it' which tells us nothing.
