Sergiosmvc
- Apr 1, 2019
- Portugal
I saw in other forum that can be ground issues...
We are talking about sonic noise, not electrical noise. You measure it with a microphone, not an oscilloscope!It’s rather “just a noise” from the step-down converter (3-wire kit). The best tool for diagnosis is an osciloscope - then you can try to filter it(small ceramic capacitor, low-pass filter, etc.)
Correct, and the switching frequencies and audibility will vary depending on input voltage to the camera, so I assume the voltage from the hardwire kit is a little different to the voltage from the accessory socket adaptor.It's just switching noise from the camera's power module.
Power supply output is filtered.
How would it do that? Unless it reaches the speaker!Do you think the electrical noise is not able to produce a “sonic noise”..?
Sure, could be. But good-old USB has voltage range about 4.5-5.25V, so 3-wire kit is in specs (if it's "filtered"). Then the camera has pretty sh*tty "power module".Correct, and the switching frequencies will vary depending on input voltage to the camera, so I assume the voltage from the hardwire kit is a little different to the voltage from the accessory socket adaptor.
Btw: How do you know it's "filtered"? If you see a stable 5V via multimeter, it doesn't necessaraly mean it's rocksolid 5V... (if a multimeter is slow/cheap enough, you'll see 5V even from 12V PWM with 40% duty cycle)It's just switching noise from the camera's power module.
You need a voltage divider (2 resistors or a potentiometer) not just one.lower the voltage of HK3 from 5.2V to 5.0V (a series resistor)
No, camera takes far too much power for that.You need a voltage divider (2 resistors or a potentiometer) not just one.
Ok, i measured the cigarette lighter adapter:
-without camera -5.07V
-with operating camera 5.04V
I also measured another cigarette lighter adapter with 4.96V, also silent.
I think Nigel is perfectly right, tomorrow I will try a germanium diode on the red wire, I am 95% sure it will mute the high-pitch noise...
I just heard back from Viofo regarding the support ticket I submitted. Apparently, its engineering team is working on a new and improved HK3 hardwire kit. They're sending me a test kit to try.
They've said the same thing to me months ago. The new kit was expected to be ready by the end of April. But It seems that there is a delay on that.
