he's part of their internal beta test group, his reply wasn't a guess
Well that changes everything then. Thank you all.
Ok, so now six weeks later, is there any news on an ir-equipped rear camera option, or is it still just a possible idea for the future?
Next we need the 3-channel version of the main camera so that we can record front+rear+interior.in production already, you should be able to purchase it next month
4 is no good,Solution is available now to support up to 4 X 1080p30, no doubt you'll see more options come to market as things progress
Sample is available, we are still adjusting the IR led and do more testing.Ok, so now six weeks later, is there any news on an ir-equipped rear camera option, or is it still just a possible idea for the future?
One power cable in & 3 (or 4) remote camera cables going out. That could be tricky to hide on the windscreen.Solution is available now to support up to 4 X 1080p30, no doubt you'll see more options come to market as things progress
I figured that would be the case.not the type of device where the guts of it would be inside one of the cameras, would all be remote cameras
Are such devices still tied to storing on a single removable SD card, or are other options available?
3 cables going on the left and 3 on the right. I added the power cable and GPS cable.So does that mean we need 4 long cables running down the A pillar into the cool right next to each other and causing interference with each other and the radio antenna?
Yes, you need to like installing cables for one of those! For most people the current dual cameras with one in the main unit is more convenient.3 cables going on the left and 3 on the right. I added the power cable and GPS cable.
I think this camera have its market share but will have limited clients.
There are other market zones where there are no products like on buses, trucks; some device which is more a security camera than a dashcam, with internet connection to the company base. This zone is much bigger compare to 4CH dashcam zone.
enjoy,
Mtz
Hi,Sample is available, we are still adjusting the IR led and do more testing.
I believe that a possibility to write data onto two memory cards in parallel (the same data at the same time!) would be pretty valuable and not too complex to implement. An obvious use case is: after an incident/accident, you give one memory card to road police, while the second one stays with you -- instead of attempts to copy files somewhere in panic after a crash... smartphone not able to accomodate a memory card, wifi of dashcam not working, no laptop etc. Of course some technical problems (detect presense/absense/removal-on-the-fly; card-by-card free space management to name a few) of a secondary memory card have to be solved.there are other options, whether that's practical or not though is another matter, you don't design these things based on what's available right now though or they're out of date by the time they're done
R | Viofo A129 Duo not recording if rear camera is connected | A129 / 129 Duo | 1 | |
A129 Rear Camera Or Cable Fault? | A129 / 129 Duo | 14 | ||
A129 Duo Rear Camera Issues | A129 / 129 Duo | 9 | ||
F | A129 Duo - Can you mount the rear camera on the windshield?? | A129 / 129 Duo | 14 | |
M | A129 duo rear camera mount replacement | A129 / 129 Duo | 2 |
