No problem with the rear camera "A129 plus duo with eMMC randomly losing rear camera connection in parking mode"
I tested the Viofo with a laboratory power supply the A129 Plus before installing it in my vehicle
I would like to thank the VIOFO Official website via Aliexpress because the first HK3 kit ordered did not work in cut-off, it always left current, it only cut from 10.2 Volt in the 4 positions
He sent me back another kit without problem by express and without asking me to send it back to me.
I advise you to check your kit before a final installation because if I had not done the test I was going to install it to find myself with a battery in a very short time HS with a cut to 10.2 V
The tests:
For the VIOFO kit for my new A129 Plus Duo camera, here are the readings:
Setting 11.8: the camera always operates at 11.74 Volt at 11.73 Volt it cuts off
Setting 12.0: the camera always operates at 11.94 Volt at 11.93 Volt it cuts off
Setting 12.2: the camera always operates at 12.12 Volt at 12.11 Volt it cuts off
Setting 12.4: the camera always operates at 12.30 Volt at 12.29 Volt it cuts off
