Little report of an "issue" after another round of playing around:
@VIOFO-Support
After everything was perfectly running, while using a ~12GB FAT32 partition to make sure I could test everything without constant overwrites, and doing a fresh formatting via the dashcam, I went ahead and shrunk the partition to my planned 2.5GB.
I then put the card into the dashcam and did a format like the last time.
Result:
When pressing the button once, it works correctly but when pressing it for a second time (a few minutes later), it will DELETE the first protected video(s) and only protect the second video from the second button press.
So instead of 4 locked videos, if within the 15s both times, and a full sd card, it deletes 3 of the protected videos, keeps only the latest and keeps recording.
I then did another format via the dashcam, drove for 15 minutes => identical behaviour!
I could restore most of them by using QPhotoRec from "TestDisk", since the card-controller uses every sector, before starting to write into them again for increased life-span of the card. But a few where broken and I couldn't play them back.
I don't think this is the planned behaviour?!
Do your engineers know how big the partition would need to be to get it working, like it should?
I'm testing 5GB next..
And I'd very much like to get the GPS Coordinates written into the meta-data, like others requested too.
Should I create a ticket for these 2 things?
