Panzer Platform
- Jun 9, 2022
- California
- 2024 Minimum Requirements: STARVIS 2 & HDR
Hey guys,
I’m please to announce I didn’t screw up my A119 Mini review too bad, and Viofo decided to send me the A229 Duo for test & review. It was delivered 2 days ago with the latest firmware "0623" , and I’ve only completed some basic preliminary testing.
So far my initial impression of this camera based on the fit & finish quality, and “big screen LCD”. This does not feel like a “budget class” camera. It feels closer to “Mid-Tier” if that makes any sense.
I’m late to the party, and I’ve read all the posts by @kamkar, @Nigel, @rcg530, @Paul Iddon, @Karagandinez, and @SawMaster so I will do my best not to repeat info that’s already been mentioned.
The first thing I did was a current draw test.
Normal Recoding, 2K@30 Both Channels, Maximum Bitrate. Wi-Fi & Screen OFF.
I measured 385mA @ 12.6 Volts or 4.851 Watts using the hardwire kit, and my Fluke 115 Multimeter.
Using those same settings I wanted to see how long the camera would run on my 20,000mAh (74Wh) USB Power Bank. The camera ran continuously for 15 Hours 43 Minutes. The camera never shut off, or stopped recording. I check the files on the SD Card, and they were all there, and playable.
I checked the capacity of my power bank using the Keweisi KWS-V30 USB Power Tester $10 on eBay. Shoutout to @Dashmellow for recommending this wonderful little device. It revealed my Power Bank has degraded, and the true capacity is only 18,916mAh (70Wh) and took 10 hours 35 minutes to recharge using a 2.0 Amp (10 Watt) charger brick.
When the camera was running for the 15 hours 43 minutes on my workbench in my garage, the hottest part of the day was 94F / 34C, and that’s how hot it was in my garage. The maximum temp of the front camera was 120F / 48C, and the rear camera was 100F / 37C. Of course these temp readings are almost meaningless, and direct sunlight heat testing is needed.
Using a 64GB SD Card with the above settings I got these available record times;
Max Bitrate: Front 29 / Rear 25 - 2 Hours 23 Minutes
High Bitrate: Front 24 / Rear 19 - 3 Hours 8 Minutes
Norm Bitrate: Front 20 / Rear 16 - 3 Hours 46 Minutes
Low Bitrate: Front 17 / Rear 12 - 4 Hours 36 Minutes
On Max Bitrate I get these file sizes;
1 Minute Video Front: 226MB
1 Minute Video Rear: 184MB
I tested how fast the two Wi-Fi bands are at downloading a 1 minute (226MB) video clip to my iPhone SE 2020 using the latest version 2.8 Viofo App.
2.4GHz: 36 Seconds
5GHz: 18 Seconds (2x fast)
I can’t wait to get this thing installed, and take some day & night time test footage.
I like the Voice Notifications so much I made a short demo video;
-Chuck
2.4GHz: 36 Seconds
