Dashmellow
- Sep 22, 2013
- Uncanny Valley (●_●)
- Umpteen
That is one reason why good cameras have the card exiting from the the sides, never from the front or back where the g-force of an accident may move it.
It is actually locked, but only by friction, it is always reasonably easy to pull one out using pliers.
I see what you are getting at NIgel, but If you ever were to witness the occasional conditions of the some of the mountain roads regularly I drive on you would understand that it may not matter what direction the memory card slot is facing. The shocks and vibrations can be rather intense and sustained when one is driving dirt and gravel roads during certain times of year.
All in all, of the various shock and vibration issues I've had to contend with in 12 years of dash cam ownership and testing, having a memory card pop out or lose connection has never really been a problem. Perhaps once or twice, if that and then I've never been certain the memory card was at fault. I'm more likely to experience a power drop out from a cable plug working loose or perhaps a camera vibration or mount problem.
