country_hick
- Dec 10, 2014
6 reasons to own a dash cam. read this.
https://dashcamtalk.com/forum/threads/6-reasons-you-should-own-a-dashcam.5022/
When it comes to dash cams you take the huge risk of buying something that is not what you think you are buying. To many generics exist. Several of these generic cameras are made to much lower specifications. As a result these could have a very short life and have substandard performance when they do work. Buying only from recommended sellers as shown on this site can help protect you.
Buying directly from China is cheaper, but you risk huge shipping costs (Possibly $50 or more) if you have to return the dash cam. Even if you do return the cam the seller can refuse to accept it. Then you have lost all of your money. A seller in your country gives you much better legal protection and probably service. Using square trade on ebay may help to protect you. Then again, square trade had some complaints filed against them.
Read this to see how shipping defective cams back to China can be a real problem..
https://dashcamtalk.com/forum/threads/best-place-to-buy-0806.8669/page-6
How many dash cams should we install?
One facing forward is a good start. 2 pointing to each side can provide better proof of what really happened. Sometimes in a crash you do not see what comes at you from the side with just a front facing cam. A rear facing dash cam might come in handy. If you get rear ended and the other driver commits hit and run you can probably catch the drivers face and his license plate. For the extremely paranoid having another 1 or 2 cams covering the interior of your car could prove what happens if you get stopped and your car is searched. You could prove the police planted evidence if it were to ever happen.
If your car or truck has interior lights that do not shut off as soon as the doors close this can provide a few extra minutes of recording time.
https://dashcamtalk.com/forum/threads/wire-dashcam-interior-lights-live-feed-longer-recordings.2363/
Lens. How to clean.
Your lens being plastic or glass does make a difference.
How do we know if our lens is plastic or glass???
https://dashcamtalk.com/forum/threads/cleaning-lens-with-alcohol.2222/
Battery verses capacitor.
Lipo batteries can overheat. They can catch fire. They can also die after a few months of normal use. Recharging a frozen lipo battery can lead to bad results including a very short life. Lipo batteries do not do well in hot weather especailly inside a locked car. They can expand and overheat causing dash cam damage.
Capacitor. If made well this holds enough power to shut down the dash cam and save the last file. In a crash if the charging cable gets disconnected you could lose power and stop recording before you wish to. (Apparently a super capacitor wears a cape and fights crimes.)
Memory cards. (Good quality name brand sd cards not cheap no-name ebay junk)
Keep a spare in your car or truck in case you need it. After something happens you can swap out cards to protect your recording. You can also replace a failed sd card quickly with your spare.
Read this for more sd card information related to dash cams.
https://dashcamtalk.com/forum/threa...s-best-what’s-even-suitable.3565/#post-119762
Is formatting required? Read your owners manual. It may say yes and to do so often.
The sd card needs to be formatted before it is first used. Some dash cams with issues may require much more frequent formatting. If your dash cam captures to many events and locks the file you may run out of free room and need to format the sd card.
If your car is on for 1 hour a day 5 days a week your dash cam will be on 261 days or 261 hours a year. In theory a 32GB sd card should last at least 30.65 years. However, there will always be exceptions and failures.
Lens. How to clean.
water is the safest although I'd just clarify that as being a damp cloth only, if it's a glass lens it's not going to have problems with mild cleaning fluids however it's all too easy for it to get elsewhere so I'd still avoid using them and just stick to the damp cloth, personally I use a microfibre cleaning cloth (dry), there's more chance of a dirty windscreen in most cars, don't use household glass cleaners as it develops a haze on the inside of the windows about 12 hours later
if it's a plastic lens like most cheap cameras have don't use anything other than a dry cloth, don't use tissues or cotton buds as they leave bits behind that may be too small to notice but will show up in your videos
Strictly speaking there's no requirement to format, it's just preventative maintenance as a file error could cause recordings to fail
The problem with cheap no name memory is not just cheaper components, a lot of cheap cards use second hand flash memory, it's a lot more common than you might expect
The better quality Flash Memory has around 10,000 ---> 1,000,000 write cycles.
Source: http://www.maximumpc.com/article/white_paper_flash_memory
where are we with endurance now? - in 2013
Today's commodity 2D MLC flash has raw wear-out in the 2,000 to 3,000 write cycle range.
Pioneers of 3D flash say their SSD endurance is better. But how much of that is due to more expensive substrate materials and how much is done by the controller isn't clear yet. So for the purposes of this article everything below is about 2D (planar) nand flash.
Source: http://www.storagesearch.com/ssdmyths-endurance.html (link seems to be broken)
Let's assume that our 32GB card can hold 4 hours of video and we'll look at a low 2,000 cycle rate and the 10,000 rate. Every 4 hours of video recording results in 1 cycle of the card.
2,000 cycles x 4 hours = 8,000 hours of operation or 333 days of continuous operation.
10,000 cycles x 4 hours = 40,000 hours of operation or 1,667 days or about 4.5 years of continuous operation.
This brings up an interesting thing, if you set the recording data rate from a high 17Mbps to a low 12Mbps, the cycle time is longer almost 6 hours. This would lengthen the life of the card by almost 1.5x.
