budster
- Feb 21, 2015
Did you put it hard up against the side of the mirror?
It's not totally flush against the mirror mount but almost. The black dot area on the passenger side is smaller than that on the driver's side. If you look at one of the interior pictures above, you can see at the bottom of the black dot area, the width is almost only as wide as the dashcam itself. On the other side of the mirror mount towards the driver side, there's a lot more black dot area space. I don't sit on the passenger side that much so just noticed the unequal black dot areas around the mirror mount while moving the dashcam.
I think I'll just keep it where it is for now as I don't anticipate unmounting the dashcam frequently to access the memory card. If I lower it, it may get in the way of a sunshade for the windshield. And I think keeping it higher in the black dot area will be better to deflect the sun and keep it cooler, plus it's a little more hidden from the outside higher up.
