Best Motorcycle Dashcam for Recumbent Trike?
PeteCress
Paoli PA, USA
The trike has 12v available from the power assist battery..
"Musts":
  • Connectivity to my Android phone for reviewing footage.
  • Accident capture where g-force causes last N seconds tb saved and not over-written.
  • Manual option for accident capture
Live monitor probably a minus instead of a plus, given phone connectivity.
Image stabilization would be a strong plus.
Not sure which id better: a single unit with fore and aft cams or just two independent cams - one for front and one for rear.
Recommendations?
Nigel
Devon
Gitup F1+G3ꞈꞈꞈꞈꞈ Viofo A139ꞈꞈꞈꞈꞈ Blueskysea B4K+B2K
You could look at the Viofo MT1, which I put on my Bicycle:
kamkar
Denmark
10 years, many dashcams
wifi are pretty wide spread in dash / handlebar cameras today, but it are still pretty slow, you are not going to get the same experience like at home connected to your router.
Event sensors like G sensor are also in most cameras, it will ensure the event is locked in a read only state, but the camera are recording all the time, so with a reasonable sized memory card, you will have to drive for many hours after a event before it is the oldest and get deleted.
For recording after a event you are better off using your phone, you can not detach a dashcam and walk around and film with it, the ones that have a battery, just like the capacitors it is just there to finalize last file in a major event, it is not there to power the camera for any length of time, the lipo batteries also die pretty fast as they do not like excessive heat or cold.
2 sperate cameras can be done, but i would not bother in this day and age, most if not all MC cameras are also dual camera these days.
Some cameras do have a screen on the main unit but it is just for doing settings ASO, it is not a good OLED screen but rather cheap LCD screens so would be garbage in the sun anyway, better to hide it all and be sneaky.
Most wifi cameras, you also have to turn on the wifi, it is not like they boot and the wifi are just on so you could automatic connect to it like BT. wifi on also generate heat, which can be more of or no problem depending on where you are.
I think we are past it now, but not long ago if you turned on wifi in a dashcam, the system would lower bitrate ( image quality ) to be able to handle that extra load of having wifi on, but i think thats done for now in systems using modern hardware.
As for mounting, you waqnt to do that of something very rigid, or you will have shaking / jello in the footage, so sticking that camera to your fairing,,, thats probably not going to work.
abarth
SF bay area, California
SGZC12RC░░ mini0805░░ viofoA119░░B1W
Camera stabilization is a lot more important on a bike than on a car since it's got a much shorter wheelbase and may not have much if any suspension. That's the reason I use Viofo cameras in the cars and GoPro or DJI on the bikes.
Here's a snippet of my daily bike commute. A regular "dashcam" would have very, very shaky footage.
And here's a snippet of my commute home in my car. Definitely not as smooth as GoPro or DJI footage even though it has a longer wheelbase and suspension.
I don't think I would like a permanently mounted camera on the bike. It's too exposed and it's another thing that would attract the wrong type of people to mess with it if it was parked during a grocery run. Instead, I use the "quarter-turn" mount that the DJI Action Cam uses for ease of install and removal. The battery lasts typically longer than my commute and if I needed to power it for a longer period, there's a USB port that powers it from my Yamaha.
