Black Friday/Cyber Monday Buys - Need help!!!
Which Dashcam Should I Keep?
  • Viofo A119 Mini 2
    Votes: 0 0.0%
  • Vantrue S1 Pro 2 Channel
    Votes: 0 0.0%
  • Vantrue N4 Pro 3 Channel
    Votes: 0 0.0%
  • Total voters
    2
SonOfKorhal
California
VIOFO A229 Pro 2ch
I purchased these four cameras with the hardwire kits and accessories.
I am also unsure which micro SD card to keep.
I plan to hardwire from a professional unless there is good DIY instruction somewhere (I am unsure how much this should cost in CA).
Parking mode would be nice to have because I live in a condo/apartment complex.
Please help me weigh the pros/cons to help decide.
Thank you!~
  1. Viofo A229 Pro 2 Channel - https://a.co/d/a9XLjn8
  2. Viofo A119 Mini 2 - https://a.co/d/drutV4v
  3. Vantrue S1 Pro 2 Channel - https://a.co/d/1tciF1K
  4. Vantrue N4 Pro 3 Channel - https://a.co/d/4ORLh2n
  • Vantrue 3-Lead Acc Hardwire Kit for Dash Cam, 5 Low Voltage Protection Options with Shifting Gear for Parking Mode, 14.8ft Type C USB 12V-24V to 5V with Fuse Holders for N4, N4 Pro, N5, S1P, E1, E2, E3, N2S - https://a.co/d/89uGdlo
  • VIOFO HK4 Acc Hardwire Kit, USB-C Hard Wire Kit for T130/A139Pro/WM1/A229Duo&A229PLUS&A229PRO,/A119MINI2 Dash Cam, Low Voltage Protection for Parking Mode - https://a.co/d/9KDadNl
  • VIOFO Circular Polarizing Lens CPL Filter for Use with A119MINI2, A129 Duo, A129 Plus Duo, A129 Pro Duo, A129 IR, A119 V3, A119 - https://a.co/d/aOBlU3A
  1. SAMSUNG PRO Endurance 256GB MicroSDXC Memory Card with Adapter for Dash Cam, Body Cam, and security camera – Class 10, U3, V30 (‎MB-MJ256KA/AM) - https://a.co/d/3sIFOoy
  2. VIOFO 512GB Industrial Grade microSD Card, U3 A2 V30 High-Speed Memory Card with Adapter, Support Ultra HD 4K Video Recording - https://a.co/d/5E3iEat
Viofo A229 Pro and the Viofo microSD card is what I would keep out of those; along with the HK4 hardwiring kit.
I'm not sure if the production Vantrue units have the rear camera fixed yet, which might be one of the reason one might not recommend them as some testers (myself included) have noted out of focus issues on the rear camera.
Install really depends on the vehicle.
DIY or Pro installation for:
2009 Mazda 6
2015 Acura RDX
How much should a pro install be in SoCal?
2009 Mazda 6
2015 Acura RDX
It's more of how comfortable are you with electronics and popping panels off? With older vehicles, I'm sure there's some instructions online to install dash cams or radar detectors.
If you're not comfortable installing, my guess is that install cost could range anywhere from $100-$200 per vehicle.
Is hardwiring or battery pack better? (I assume hardwire is better because I did not know about the battery pack option until later.)
From what I have been reading it is best to take your car to an audio shop to properly install/hide and hardwire for parking mode.
I was wondering if anyone had experience doing the installation with BestBuy.
I was also considering this local shop https://sorenacaraudio.com/
