flint350
When I had my old Blackvue 900s and Battery 124 professionally installed in my Mercedes by a custom audio shop, the install included an on/off switch for overnight garage parking, etc. The switch was wired to the BlkVue battery in the trunk which is tricky to accomplish well and why I didn't try it. It worked flawlessly until the front camera died, requiring a replacement. The battery was still holding charge fine and hardwired to the system, so all I replaced was the camera with the new 970x. However, this required replacing the wiring as the new cameras use a 3 wire setup not supported by the old wiring.
I had this wiring replaced by a Best Buy shop and the tech said the on/off would work as before and the new wiring for the cameras was replaced as required. Once I got home and tried the on/off switch, my problems began. The on/off switch now gets the camera to say "parking mode on" or "parking mode off." I can't get it to shut down the camera, no matter how often I push it or hold it, it just responds with the parking mode. Best Buy has no answer and says it should work as before, but it doesn't. I don't know what has changed and really hate having to unplug the camera every day. That can't be good over a long time for the plug or camera. Sorry for length but I wanted to be clear as to what changed and why. Any ideas on this other than going somewhere else (like a car audio shop)?
