acemundo said:
Hi all,
my viewer is loaded with korean language instrucitons. how do i switch it to english language?
from the manual i have downloaded, it does not teach us how to change the language settings, adjust time. even when i selected region to my home country and tried to save with the icon in the center, one message in korean pop out, presumably telling me it was not successfully
when i installed it, one message in korean appeared but I couldn't figure out what it is trying to inform me to do.
Alright Here is how to fix it FOR BLACKVUE DR400HD SEASON II ONLY
Go here and download this
http://depositfiles.com/files/4iaj1kgje
Change Korean Voice to English
If you are running firmware BlackVue DR400G-HD II v1.010K which has the Korean voice prompts, there is a way to change this to English voice prompts. You must be running v1.010 Korean for this to work.
You must use an SD-Card reader to perform this operation. Do not attempt to do this directly on the dash cam.
Insert the micro SD card into your PC.
Download the New_Blackvue 1.010K to all English.zip file.
Copy (drag the Blackvue folder ) on a blank SD card and FLASH in your Camera.
If the above option does not work, the following alternative option may work:
Download English voice firmware from Rapidshare.
Download English firmware for DRG400HD from Blackvue.
Replace folder Application( step 1) with same folder from English firmware for DRG400HD (step 2)
Go to folder BlackVue\Config(step 1) and open file VERSION.BIN with Windows NOTEPAD. You have to change: 1. [software] model = 400GII to 400 and 2. [config] version = 1.010 to [config] version = 1.000
The new VERSION.BIN should look like this
[firmware]
version = 1.010
model = 400GII
language = Korea
[software]
version = 2.010
model = 400
language = Korea
[config]
version = 1.000
model = 400GII
5. Save all changes
6. Insert SD card in to your Blackvue DRG400-HD II. I takes a few minutes to upgrade.
7. Enjoy
FOR THE BLACDKVUE DR 500G HDWIFI DOTHIS
Go Here and download
https://mega.co.nz/#!ecdzlJKB!FlFgpSihc ... bCF6Se_r4g
Unzip it to a folder
The instructions are included but briefly here's what you do
Firstly save the contents of your Korean SD card to a folder on your computer
Format the SD card
Load the unzipped FOLDER (Blackvue) onto the newly formatted card
Put card in camera and wait till it says "The version information is different".
Turn the camera off and put card back into computer go to Blackvue/config/version Change the KOREA in both lines to ENGLISH.
Or copy and paste the "VERSION" file from the folder u unzipped to. Does the same as above
Put it back in the camera and wait for about 3 mins till it says its restarting the Blackvue Will now be in English
