- Apr 14, 2013
- Minsk
- Belarus
- Street Guardian, BlackVue, Thinkware
January 30, 2015
We made a custom firmware for Blackvue DR650GW-2CH with support wdr, bitrate, etc.
Started testing.
raw: https://yadi.sk/i/h8TMsBjpeRHdn
raw: https://yadi.sk/i/OddxBwMyePgGA
WDR/ISP - the moment switching
Started testing.
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 597 MiB
Duration : 6mn 6s
Overall bit rate : 13.7 Mbps
Encoded date : UTC 1970-01-01 00:00:00
Tagged date : UTC 1970-01-01 00:00:00
Writing application : Lavf52.34.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 6mn 6s
Bit rate : 13.6 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.219
Stream size : 595 MiB (100%)
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 6mn 6s
Bit rate mode : Constant
Bit rate : 48.0 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 16.0 KHz
Compression mode : Lossy
Stream size : 2.09 MiB (0%)
Codec ID : isom
File size : 597 MiB
Duration : 6mn 6s
Video
Format : AVC
Codec ID : avc1
Duration : 6mn 6s
Color space : YUV
Bit depth : 8 bits
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 6mn 6s
