Not sure why it's not working for you. Where did you get the firmware file from and what is your update process?
Firmware file from this resource :
Update process as described on this firmware page
to save files with the M button the G sensor must be on low (minimum) or it dosent work.......is your G sensor set to on?Firmware file from this resource :
I just tested this and the emergency lock button (M button), works on all 3 sensitivity settings on the camera I have here.to save files with the M button the G sensor must be on low (minimum) or it dosent work.......is your G sensor set to on?
I was just making sure mihails had set the G sensor to onI just tested this and the emergency lock button (M button), works on all 3 sensitivity settings on the camera I have here.
Ahhh, I thought you were saying it only works on low. My bad!I was just making sure mihails had set the G sensor to on
Maybe you are re-installing the original firmware? I uploaded the firmware I have to Dropbox if you want to try it. It works on the cameras I have here.G-sensor enabled, but M button doesn't work I tested "Medium,Low" G-Sensor level.
Thank you! Now it works! I see the lock sign and this fuction work !Maybe you are re-installing the original firmware? I uploaded the firmware I have to Dropbox if you want to try it. It works on the cameras I have here.
https://www.dropbox.com/s/cksuaekibzgoc5j/FW96650A.bin?dl=0
The latest version 2.7.3 of dashcam viewer works correctly with the G1W-SI think it is the latest firmware. Firmware updates are unlikely but might happen so any fix to speeds in a viewer would likely need to be implemented in the viewer instead. If more folks bought this bargain of a cam, I think Viofo would put more effort into it but sales lag and he's a very busy man
"Dashcam Viewer" seems to be the viewer getting the most attention and updates right now. @traveler is it's designer and a member here so he should see this now and maybe he can help out
Exactly.Does manual save not work when G-Sensor is turned off?
