Camera freezing up??
Daffypuck
Tennessee
About a wek ago I was reviewing some clips and clearing the card of saved events and noticed one of my clips was a frozen image but the audio was recorded for the entirety of the clip with only one frame of video. So Ive been keeping an eye on it and it seems to be happening quite regularly now. Tonight after work, I got in my truck and plugged in the power cord and glanced up and the video was frozen. It took about 3 times of unplugging and plugging back in my power source before the video started showing live video while it was recording. Any ideas what may cause this? Firmware update maybe? Perhaps reformat the card? I dont believe Ive formatted this card since I got this cam last March. It only gets about 1hr of use per day. Back in the summer though, I had it on damn near 24/7 for about 3 weeks though on a ccross country trip.
What is the serial number off the back of the camera, and what firmware version are you running currently? Which memory card are you using? (make/model/size) You should format the card at least a few times a year just to keep the card healthy. Do you use Windows or Mac?
formatting the card occasionally can be a good thing, the memory card is the weak point in any camera
also can you let me know firmware version, serial number of the camera and which memory card you're using, brand and size
Ok, Ill get back to ya this time tomorrow night. Too cold to go outsidenow. Thanks.
Ok, heres the info: Ser#GSGC15250033 firm#SG20150526.002 and its the card that came with it. A Kingston 32gb. I formatted the card and will see if that solves the problem. Thanks yall.
Looking at the above link to the firmware update, Im a bit confused at which update I should download. Neither matches my SN.
there was a known issue with the firmware version that you've been running that can cause the problem you had
you need this one
Model No. SG9665GC
Versions: SG20151109.002 & SG20151109.V2
Date: 2015/11/09
Updated firmware for the SG9665GC is now available, please choose the appropriate version based on your camera serial number and existing firmware version number
Street Guardian SG9665GC V1 (SG9665GC.bin) http://www.mediafire.com/download/rj3anbntosnch0b/SG9665GC_V1_Update_1.zip
For camera serial numbers SB15xxxxx through to SGGCxxxxxxxx
Settings menu display version number SG20xxxxxx.002
