The C2 lens will only give you a wider FOV. The night performance depends only on the sensor. Unless you're thinking of replacing the whole module (lens + sensor), which I don't recommend, not until they sort the current issue out.Can C2 lense be installed in any mobius version? It seems that it gives better night performance.
Also is the performance difference worth the upgrade?
Can be changed no problem, just select the appropriate setting in the config to suit
Case was adjusted to suit an updated lens base, just the lens is no issueAccording to some reviews I read it needed a new case. Is this true?
