Hillbilly
- Feb 14, 2013
- Sunshine Coast
- Australia
- DR750s x2 DR450 x2
spoon said:Yes I know what you mean because of the motion detection it will trigger the most recording,so I might need to set the motion detection to its lowest point or off it...might give it a trytonymy01 said:What kind of visible motion is happening in front of the lens?
You didn't get my point, if you have motion detection set to even a small amount (not the G force one,I am talking about the other option), then any visible movement in the field of view of the camera will have recording (from ten seconds before the motion was detected). I have had to turn mine right down and hope the g-force being set nice and high will trigger if someone bumps into the front if my parked car, otherwise even my alarm led blinking and reflecting off the windscreen glass is enough to be detected as visible motion (near zero will mean only large detections of motion will trigger).
My 350 which is in the rear window goes into parking mode after 10 mins of no car movement then shows as in parking mode.
If its in a supermarket car park it keeps recording as long as there is even a tree blowing or someone walking 50 M away.
The motion detection was set at 50% which is too high. I have reduced it to 25% and will see how it goes.
The G force is also set at 50% and havent tested it but will do so.
In my garage when I back in it keeps recording for the 10 mins and then stops recording After 1 hour it says Blackvue shutting down even though there has been no movement at all for 50 mins
You can turn of ALL LED's and nothing will show. All mine and all audio warnings are OFF ALL THE TIME
