FYI: My last firmware was 2013.1126.16. (issue: last file error because the unit didn't shut down properly)
For G1W-C user who have this kind of issues:
- Last File error
- unit didn't turn off properly
- Setting became default after reboot
Try this firmware. it will upgrade your firmware into 2014.0813.11 .
I've upload it to my Google Drive.
https://drive.google.com/file/d/0B90I_Yu3gbxGNDQ3NGg0Mi1xamM/view?usp=sharing
n.b. do it at your own risk!!!
TUTORIAL:
1. Download from the link above
2. Format your Micro SD
3. put the Bin File on root of your micro sd
4. Plug in the Micro SD
5. Plug in the USB (to power up the G1W-C)
6. The screen goes blank for few second, and then boot up
7. Check the firmware version. it should be 2014.0813.11
8. Format Your card using the G1W-C
9. Try to reboot if the problem still exist (mine works fine after 4-5times reboot)
10. Hope this work for you guys.
There's some filter that will reduce or fix this problem. I forgot the name.Just took a first ride today to work. Everything works fine as it should be.
When the sun shines on traffic light, red light or green light look the same: silver, bright color on recorded video. Only see clearly color when the sun behind the traffic light. I guess this normal, not camera fault. That would be a problem when a cop gives faulty ticket.
...Only see clearly color when the sun behind the traffic light. .... That would be a problem when a cop gives faulty ticket.
I just noticed the led flashes.A question about the red flashing led. I thought it was just a light that flashed to indicate recording was on. I tested a new 16gb Samsung EVO card today and the led flashed with varying intervals, sometimes a few quick flashes, then some slow ones. Made me think that the led flashes when the card is written to. Makes sense as in testing this 16gb card on a win8.1 pc the graph of write speed was all over the place, from about 5MB/s to 12. Most other cards have fairly flat write speeds. It was also pretty hot in the car so that may be an issue.
Maybe this is why my other class 4 card caused lock ups, too slow to write, especially as there is a time overlap in files meaning whilst finishing one file the system has to start another one, so a slow write at that point may crash the system
Just a thought. Anyone else noticed varying led flashes when recording?
I do not know where I should buy it ?
But are we sure that foxoffer will always sell the same ?
