to connect to 12v circuit, you need 12v to 5v miniusb converter:Okay, I ordered one along with a mirror mount. I have a question I have probably should have been asked before I bought it- Will the camera run off of a USB port? My car has 4 USB ports but only one "lighter-style" outlet that I would like to leave open for a GPS or anything else that can only use that type of socket for power. My car also has power running to the mirror and my best option would be to piggyback on the 12v power that is already available right next to where the camera is going to be mounted. Has anyone done this?
Yes, you need this !That is not something I would need. My car's USB ports have the voltage that it would need, if I used that option. So you are saying that this camera WILL work off of a USB port, Niko?
@ yours:
.... My car also has power running to the mirror and my best option would be to piggyback on the 12v power that is already available right next to where the camera is going to be mounted. Has anyone done this?
My point was that piggybacking onto the 12v power already in my mirror would allow me to NOT use the lighter plug, which is also 12v. I just have no idea how how to do it and I bet somebody does!
yes, I got your point, thats why gave you proper solution.My point was that piggybacking onto the 12v power already in my mirror would allow me to NOT use the lighter plug, which is also 12v. I just have no idea how how to do it and I bet somebody does!
U may also run USB to mini-usb cable. Its up to you which way you go.A USB port always has the same voltage to be able to be USB. I wouldn't need an adapter for a USB port because my car has USB ports. Will the camera run on a USB power source or does it need to be plugged into the 12v outlet?
The advantage of running from mirror or reading light loom is option to have 30-60sec powet-cut delay after ACC switched off.
If directly from usb port in your car, then there is an instant power cut, or worse case that usb port is always 12v, then you need switch on / off dashcam manually.
You are welcome.Well I have decided to put 1 of these in my truck also.
Thanks for the nice review niko.
Fox offer has 1 headed my way and I can't wait to get it in my hands.
