- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
is yours from Foxoffer?
my g1wc has the same firmware.Hi all
I got my Blueskysea G1W-C 2 day ago, with the firmware of 2013.1112.18. Running it with my PowerGen Dual USB 4.2A 20W Car Charger and a mini USB cable, no problem as far.
One thing I find is that the contrast is little high on a bright sunny day, I wonder turning off the WDR may help? Since the firmware of mine doesn't allow me to turning the WDR off, so is it a better firmware to flash to the dash cam ? Thanks.
There is a example of the dash cam video below, I think this cam is very good value for money.
I don't have that problem.my g1wc has the same firmware.
does your nite videos have lights that bleed? (see previous page for an example.)
Is there a way to interface a GPS unit into the dash cam?
I have a Tom Tom unit, but would be willing to consider buying another unit if it is possible to marry the two units.
Video looks very good.Hi all
firmware for battery and capacitor versions are different, if you got a battery version on there you'd find the last file would get corrupted all the time on shutdown as the battery version doesn't power down quick enough
New camera - firmware version? G3 33dp v07 . I bought a camera with supposedly a 140 degree lens as in this thread http://dashcamtalk.com/forum/threads/gearbest-g1w-c-41-99-after-coupon-code.6583/ How do I tell if is is really a 140 or just a 120 like most of the G1W-C models? What is the Carplate function for? tiaReview of C1W-C ( Capacitor based ) Dash Camera
This is a "brother" of well known budget dash camera G1W that got popular this year as a good value for money car dvr, which is based on popular combination of Novatek NT96650 CPU and Aptina AR0330 CMOS sensor with F1.8 lens aperture.
Overall G1W and G1W-C main specifications, performance and video quality recording is the same apart from G1W is uses built-in battery and G1W-C is based on Capacitor ( dual SuperCap ) which allows to save last recorded video clip and keeps time and device settings in the memory.
Till now there are only some Korean high-end dash camera manufacturers used capacitors instead of batteries, but end of 2013y showed more and more high-end dash cam manufacturers realising problems if using batteries inside dash cams, so they now going over to capacitor based dash cams. But we all know that Korean high-end dash cams are quite expensive and not all people can afford them.
G1W-C is the FIRST Chinese dash camera which is based on Capacitor. I haven't even seen yet any mid- and high price-range Chinese dash cameras based on capacitor ( 50-150 usd price range ). So for G1W-C developers being budget dash camera it is well made decision to start producing dash camera that can be affordable and at the same time with good specifications and performance.
Pros / cons of capacitor vs battery in dash camera.
Battery based dash cams has been reported having problems working in hot countries, due to battery overheating or even exploding. Many manufacturers advertise having battery in dash cam as positive thing, - you can record videos even without external power source, - yes thats true, but let's think in real life we all have mobile phones these days, so we can use them to record footage outside the car if needed. Most battery based dash camera will record around 20-30 minutes if fully charged and this is when they are new. ( latest Mobius and Innovv can record about 1h +/- ). After some period batteries lose their memory ( capacity ) and you are lucky if you can record few minutes footage. After some period of use batteries in many cases can die, so you end up in situation where your dash camera will not save last video file which is in most accidences is the most important video footage you want to keep as an evidence.
With Capacitor based dash cameras there are almost no worries with overheating issue, no exploding batteries, no risk of last file not saved. The only drawback with capacitor based dash cameras is that you can not record footage without external power.
Package content of G1W-C is standard as with most budget dash cameras.
- packaging
- dash camera
- suction mount
- miniUSB to USB2.0 lead
- miniUSB cigarette lighter charger / power adaptor
- user manual in English, Russian and Chinese lanugage
Menu interface is the same as on G1W
Main Features:
· FULL HD 1080P high quality resolution.
· NT96650+AR0330
· 120 degree A+ grade High Resolution Wide Angle Lens.
· Lens aperture F1.8
· Wide Dynamic technology ( firmware enhanced )
· H.264 video compression technology.
· Video recording in MOV
· Video recording bit-rate: average 12Mbps
· G-sensor function.
· Built-in microphone/speaker.
· Supports high capacity TF card up to 64Gb (Fat32 ).
· Seamless looping video.
· Support anti-shake function.
· Motion Detection.
· Support HDMI high quality video transmission.
· support auto ignition boot, turn off shut-down.
ADDED:
G1W-C works with Samsung 64Gb MicroSDXC ( MicroSD, Micro SDXC )
Specifications:
I turned my audio off.
I assume smaller file size since there's less data to be saved?
What are the advantages of having the audio on?
