Hack_man
Strike 3 I think you meantAs I replied to you in another thread, the OP100 cannot power the EP100 at all. The OP100 OBD-II power adapter can only supply power to a dash camera.
I was going to say BP100/EP100 but didn't put both in the post.Strike 3 I think you meantEPBP100 š
Do you mean something like thisI with they made a simple USB Type-C tester that would tell you which pins are connected by wires inside.
Is there any pictures of pins utilized on this VIOFO OBD2? I can't find a picture anywhere.
I'm curious which pins it's using. Typically I see three pins on these various OBD2 wires.
I'm not sure what pin numbers are compatible with VIOFO.
Looking at that thing... username checks out šDo you mean something like this
You have to be a member for a certain number of posts or a certain amount of time (I'm not sure which) before you can edit.Sorry forgot to add this will be used with a A329T camera.
(PS- how do you edit a post? cannot find anywhere to do it)
Everything should work without problems on any car that has such a connector.Will this power adapter work with a 2017 Mercedes E43 (W213) obd port?
Our OBD cable is compatible with all the cars that have OBD portsWill this power adapter work with a 2017 Mercedes E43 (W213) obd port?
It's the OP100 seeing the vehicle voltage level has entered into and stays in the 12V to 13.5V range and the OP100 detects the vehicle has been "stationary" and no impacts have occurred for 200-seconds. When those conditions are met, the OP100 will turn off the ACC power signal to the dash camera. When the ACC signal turns off, the A329S enters the selected parking mode or it will power down if there is no parking mode enabled in the settings. Pin 16 of the OBD-II data link connector port is fed constant power and should not turn off unless there is a vehicle battery issue or if the fuse that protects that circuit has blown.I am running the OP100 to a VIOFO A329S using the cable that came with the OP100. I gather this is not the "Optional Parking Mode Cable" on VIOFO's page,*
but I do have a question about this combination's behavior in a 2026 Toyota. When parking mode is turned OFF in the VIOFO app, and the A329S has been running while the car is on, when I turn the car off, the cam keeps running for 3:30, then shuts off. Is the OP100 or the A329S recognizing that the car is off and turning the camera off? I assume the car's pin 16 in the OBD-II remains powered when car is off but I haven't tested that.
*VIOFO's page on the OP100 implies there are important added parking functions available with the "Optional Parking Mode Cable" but what are they? configurable voltage cut-off? and when can this "Optional Parking Mode Cable" be ordered?
Thanks.It's the OP100 seeing the vehicle voltage level has entered into and stays in the 12V to 13.5V range and the OP100 detects the vehicle has been "stationary" and no impacts have occurred for 200-seconds. When those conditions are met, the OP100 will turn off the ACC power signal to the dash camera. When the ACC signal turns off, the A329S enters the selected parking mode or it will power down if there is no parking mode enabled in the settings. Pin 16 of the OBD-II data link connector port is fed constant power and should not turn off unless there is a vehicle battery issue or if the fuse that protects that circuit has blown.
VIOFO just released a YouTube video showing the OP100 in action with an A329S dash camera. They use low power impact detection as the parking mode in their example, but the same applies to any of the parking modes available for the A329S.
The parking mode timer switch lets you select 3-hours, 24-hours, or an "infinite" [timer disabled] amount of time. If the vehicle voltage level on pin 16 of the OBD-II data link connector port goes below 12V for around 90-seconds, the power to the dash camera is turned off. The exact vehicle voltage level the OP100 turns off the power to the dash camera can vary a bit since every low voltage cut-off feature [not just in the OP100] uses components that have a voltage tollerance of +/- 0.1V to 0.2V.Thanks.
Using the wire that is included with the OP100, if parking mode turned on in app, it runs for 3 hours minimum - unless the car battery reaches the 12v cutoff threshold in the OP100?
I'm not sure what you mean by optional cable. Although, the VIOFO website uses the word optional for the OP100-to-dashcam power cable. When you purchase the OP100, you must select either the USB-C or Mini-USB version of the OP100-to-dashcam power cable. The OP100 has two power ports. The USB Type-A port is where the dash camera power cable plugs into the OP100 and the USB Type-C port can be used for providing power to devices like your phone. Both OP100 dash camera power cable types are available now. I would image that VIOFO will primarily sell the USB-C version of the dash camera power cable, but the mini-USB version is available if you have an older VIOFO dash camera that has that type of power connector on the dash camera/mount.Any word on when the optional cable is available and how it should be different?
The verbiage on VIOFO's page for the OP100 does describe as optional two choices of cable for it - since I didn't order any separate, "optional" cable I assumed it was indeed different than the one that shipped with the OP100 I received. I asked VIOFO about this directly and never received a response.I'm not sure what you mean by optional cable. Although, the VIOFO website uses the word optional for the OP100-to-dashcam power cable.
