Custom Firmware Thread: *RELEASED* Ver 1.1.1aE [DR500GW-HD]
Re: Custom Firmware for DR500GW-HD | NEW* V 1.1.1(E) Coming
Beerbelly said:
I just purchased a 64gb sandisk ultra card but can't seems to format to fat32 only allow me to format to NTFS. Copied the custom fw to the card but recorder can't read the fw. Anything I should do? Tks a million.
theres a link somewhere in this thread to one that is working. if not another thread about 64gb cards. I know its here somewhere.
here we go, a simple search showed the results.
viewtopic.php?f=6&t=607&start=40#p13805
Thanks got it up and running now on my 64gb custom fw🙂
are anyone else's videos jerky at some times?
while watching a video today and at some points there's little twitch like it jumped couple of frames
yeah I get that as well a bit.
I just bought this dashcam. Been running the DOD GS-600 for a couple of years. I got tired of having to change the micro SD card on a regular basis, due to the fact that the DOD GS-600 doesn't loop properly. I use dashcams to post radar detector and laser jammer encounters on my YouTube channel. I can't wait for the latest firmware. Sending a PM to Mio now to hopefully get 1.0.5 in the meantime.
Thanks and I hope this dashcam is as good as advertized.
Re: Custom Firmware Thread: Coming Soon Ver 1.1.1aE [DR500GW
I had a bit of a problem yesterday when the GPS suddenly stopped working. I checked all the footage and for no reason the GPS (and therefore the speed reading) stopped for no obvious reason. GPS stayed off for a couple of hours then started again just as suddenly and again for no obvious reason.
When I put the SD card back into the device, the voice kept saying "Check SD card" over and over again, so I've taken it out and reformatted it, and at the moment it seems to be working properly again.
I've read the forums and GPS problems seem to be a regular issue, but I believe the next release of the custom firmware may have something like a GPS reset, which will be brilliant. I am really looking forward to it, but Mio, don't release it until you think it is perfect.
I found my gps did that on and off and then eventually died totally.
Couldn't wait to see the new custom FW. tks Mio 😀
firmware is ready, yesterday ran tests
waiting for translation of documents
Wow !! Finally !!.tks for the hardwork micheal !
I do not know if it's because of the custom firmware or it is normal but I can not completely turn off my security led. In the software I put the switch to off and in normal mode it is off​​. But in parking mode it is still blinking :? . Has anyone an idea how to permanently turn off the security led?
And what is your firmware?
Now blanking LEDs we did in 1.1.1
but we found that some work, others do not work
We now think how to make it work in all
It is the early custom firmware version 1.005ES. Actually, I'm really satisfied with this version. But to fix this thing so I would have to install a newer custom firmware version?
Nice! Looking forward to this,
The problem was not the firmware it was my own blindness 😳 . I checked the settings again and saw that there are two switches for the security led.
There are also buttons for the parking mode. I will check it when the cam is back in my car but i think the problem is solved.
Sorry for the unnecessary question and thanks for the help Mio.
here are the settings in the new firmware
Code:
[version-1.1.1a]
#                  Custom config file
# ------ Voice = "KOR/RUS/ENG
Voice=ENG
# ---------- Play Volume
Volume=95%
# ---------- Priority of the main processes
priority=20
#  Set LED's (ON/OFF)
# Wi-Fi LED in normal mode
wfled1=ON
# Wi-Fi LED in parking mode
wfled2=OFF
# GPS LED in normal mode
gpsled1=ON
# GPS LED in parking mode
gpsled2=OFF
# Set G-sensor value (Low/Normal/High/ST)
# G-sensor in Normal mode
gNormal=Low
# G-sensor in Parking mode
gPark=ST
# Set Video parameters
# 0 =  standard avserver
# 1 =  via avserver.sh in BlackVue/Config
# 2 =  custom:  AEC/AGG with AWB TI2A
Video=2
Size=1080P
Bitrate=15000000
Cabac=Yes
#  Auto White Balance (Custom/Normal)
# Custom  - custom AWB
# Normal - standard avserver AWB
AWB=Normal
# AWB Sensor (1...3): from "warm" to "cold"
AWBS=2
# Daytime Brightness (1....7)
AECB=6
# Auto Expositure Speed (1...4)
AGGS=2
# Night Brightness (1....7)
AGGN=3
# Video special
# Video Flip & Mirror = (ON/OFF)
FM=OFF
#  Set Wi-Fi Parameters
# Mode:
# APS - standard access point
# APC - custom access point
# DIR - direct (P2P) Mode
# STA - station mode
Mode=APC
#   DHCP Server/client (ON/OFF)
DHCP=ON
IP=192.168.8.1
MASK=255.255.255.0
GW=192.168.8.1
DNS=192.168.8.1
# MODE=DIR (Direct Mode Parameters)
# P2P mode
# 0 = Disable P2P
# 1 = Enable P2P
# 2 = Device will be the P2P client mode
# 3 = Device will be the P2P group owner mode (SoftAP)
P2P=1
# Mac address of the peer device
MAC=00:11:22:33:44:55
# P2P Client Mode
# display - peer P2P device should display its PIN CODE on screen and the user should key-in this code on local device
# keypad - local P2P device should display its PIN CODE on its screen and the user should key-in this code on peer device
# pbc - two P2P device will use the WPS push button for the following WPS procedure
# label - user should read the PIN code from the label of peer P2P device and key-in this PIN CODE on the local P2P device
P2PC=label
I have been reading through all this thread, but still have no idea how to get the custom fw or install it. :?
Message Mio (post above yours is by Mio), follow instructions, pretty straightforward
Re: Custom Firmware Thread: *RELEASED* Ver 1.1.1aE [DR500GW-
This is good news, cant wait to test it out.
So just copy the code above, and save the code into the avserver file and thats it?
