I'm looking for a dash cam setup for a Tesla Model S:
I don't like the SGZC12RC because of the size of the main unit. The remote lens is nice and compact, but I prefer the b40-style form factor of the GC which is all in one (this is seriously the best form factor of ANY dash cam IMO). I don't want to clutter the interior. I've seen mentioned that this is one of the lowest power draw out there (at least the panorama version) but doesn't make up for the negatives.
I also considered the Mini 0806 which beats the GC in resolution and image quality and storage capacity but it seems reliability is (was?) a problem. Plus, the fact it has a battery means I'd probably end up killing it by running it 24/7. I'd really go with this if it was capacitor-based or had a better reputation.
Blackvue is the brand I notice comes up the most frequently in Tesla forums which is kind of a surprise. It's pretty expensive for what you get, quality and reliability doesn't seem much better than lower priced cams, crappy bit rate (unless you use the hacked fw). I do like that it doesn't have a display. Also, it seems from what I have read so far power draw and heat is higher than SGZC12RC. While I'm not worried about draining the 12v battery, I do want to select a dashcam that has as low draw as possible to minimize the impact on lifespan.
There are a lot of high end cams I completely ruled out because of the ridiculous form factor and unnecessary features. If it's suction cup or too large or dangles too low it's a deal breaker. Basically anything that looks similar to a G1W or a point and shoot hanging on the window is out.
Is getting two SGZC12RC and having them run 24/7 a bad idea? Lifetime of the SD card could also be an issue, if it's short enough then I have no choice but to get a dashcam with a legit buffered parking mode, which basically rules out all the dashcams I actually like. So what would you suggest?
Sorry for the long post. Just trying to get everything I understand so far written down to test my assumptions.
- Want front + rear cameras.
- But NO dual channel. The extra wiring and poorer quality rules this out for me.
- Higher cost of two separate single channels is not a problem.
- Don't care about the convenience of having it all on one device. If I get into an accident, I'll take out the SD card and dig through the videos if I have to.
- Because the car is constantly topping off the 12v battery, I don't have to worry much about draining the battery.
- I think I'd prefer 24/7 recording (I don't mean park mode, I mean actually recording all the time).
- It seems it would be too easy to get unwanted "locked" files with park mode and g sensors from getting in and out of the car. I'd rather just have high enough capacity to have at least 24 hrs of video. I never park anywhere longer than that anyway.
- In fact, the only lock mode I really care for is the manual button-press one.
- I realize this means more charge cycles on the 12v battery and possibly shorter life span. That's OK (within reason).
- I realize that SG9665GC is not the ideal model for hardwired/park mode because of lack of buffering, but if I am always recording then this shouldn't matter right?
- Potentially heat might not be too big an issue. I live in a climate where the temps outside can get to 106 a few times a year, but on those days if I have to park in the sun I leave the AC on. That said, the AC probably doesn't help much for electronics mounted on the window in direct sunlight.
- GPS is not important to me.
- Unfortunately it looks like SGZC12RC comes with GPS and there is no option to get one without it. The GM doesn't seem to have the same video quality so it's not an option.
- I don't want an LCD but all the cams I like seem to have them. Don't mind it if I have to get one with LCD.
