DDPAI Z90 Master (New Rev) vs VIOFO A329S - $260 price gap
Zhuki
Warsaw
Poland
Hi everyone,
I am about to take delivery of a new brand-new vehicle – a Skoda Octavia IV (VAG group). As many of you know, modern VAG cars are notoriously painful when it comes to sensitive Battery Management Systems (BMS), frequently throwing "Electrical system error" codes if there is even a minor parasitic draw on the 12V battery.
Because of this, I am fully committed to deploying a dedicated LiFePO4 battery pack setup. However, my driving profile is highly restrictive:
  • ~12 short city trips per month: Mostly quick 10-to-15-minute grocery runs or commutes.
  • Only 1 long trip per month: This is the only time the battery pack will get a sustained, full charge from the alternator.
I am currently torn between two flagship setups, but there is a massive ~$260 USD price gap between them in my market. I need a technical sanity check regarding power efficiency, sensor value, and overall storage architecture.
The Contenders (All-Inclusive Pricing in USD)​
Setup A: The "Practical/Innovative" System (Total: ~$440 USD)
  • Dashcam: DDPAI Z90 Master (Latest 2026 Revision including Hardwire Kit) – ~$246 USD
  • Battery Pack: Cellink Neo8+S (96Wh LiFePO4) – ~$194 USD
  • Storage: 128GB built-in eMMC + external microSD slot.
  • Key Advantages: Supposedly un-brickable storage on short trips, discrete form factor, and lower price.
Setup B: The "Enthusiast/Raw Bitrate" System (Total: ~$700 USD)
  • Dashcam: VIOFO A329S 2CH (Front + Rear) – ~$375 USD
  • Battery Pack: VIOFO BP100 (96Wh LiFePO4) – ~$250 USD
  • Hardware Kit & Fuses: VIOFO HK6 + 2x MINI Fuses – ~$31 USD
  • Storage: High-End endurance card (Samsung PRO Endurance 256GB added manually) – ~$44 USD
  • Key Advantages: 4K @ 60fps on the front camera, full native ecosystem integration, and granular setting controls.
My Core Technical Dilemmas:​
1. The "True Dual 4K IMX678" vs. 4K 60fps Smoothness​
The authorized EU distributor for DDPAI officially confirmed that the newest revision of the Z90 Master features Dual Sony STARVIS 2 (IMX678) sensors for both the FRONT and REAR cameras. On paper, having a native IMX678 with Dual HDR protecting my rear bumper is an absolute dream for hit-and-runs.On the other side, the VIOFO A329S drops the rear down to an IMX675 (2K), but brings 4K @ 60fps to the front. As a person who values sharp frame-freezing, is sacrificing 60fps motion blur reduction on the front worth getting a massive 4K Starvis 2 upgrade for the rear?
2. Storage Architecture vs. Short Trip Power Cycling​
With roughly 12 short trips a month, the dashcam will experience constant power-cycling and abrupt shut-offs. DDPAI's 128GB built-in eMMC storage acts as a fail-safe backup parachute if the primary SD card corrupts. VIOFO is notoriously finicky with SD cards (straight up rejecting certain SanDisk models) and while it supports external SSDs, a portable SSD adds bulk and increases power consumption during parking mode. Is integrated eMMC a safer bet for a "set-and-forget" vehicle that sits idle most of the month?
3. Parking Mode Efficiency on Limited Charging Windows​
Since I only drive a long distance once a month, my battery pack charging windows are extremely tight.
  • I read that VIOFO's new LPID (Low Power Impact Detection) mode on the A329S reduces the draw to an impressive 20-30mA (under 45mA guaranteed), and its Hybrid Parking Mode allows a smooth transition from buffered detection to deep sleep.
  • Meanwhile, my research indicates the DDPAI Z90 Master pulls anywhere between 200-450mA while running Time-Lapse parking mode.
If these power draw metrics are accurate, VIOFO's LPID might actually allow the system to stay alive over long periods of inactivity on a partially charged battery pack, whereas DDPAI's constant time-lapse might deplete the Cellink battery within 30 hours. Can anyone verify the real-world parking mode mA draw for both?
4. The $260 Premium "Sanity Check"​
Is the VIOFO ecosystem, community custom-firmware support, and buffered parking mode (capturing 15s before an impact) worth a massive $260 USD premium over the DDPAI system? Or does the revised Z90 Master offer an unbeatable price-to-performance ratio given that it includes dual flagship sensors out of the box?
I know this community leans heavily towards VIOFO purism, but the revised DDPAI Z90 Master spec sheet seems to challenge the status quo.
What would you choose for a brand-new car with a highly sensitive electrical system?
Looking forward to your expert insights!
You're very particular on what you want. Sounds like parking mode is a "loss", best thing to focus on is to have great coverage during your short trips. Parking at home doesn't have a promising end.
Data charts are a bad way to gauge the performance of the new Z90.
My suggestion would be to view video footage of both cameras, from multiple YouTube creators. See which one gives you a better feel on the video quality. More accidents happen from the front and front side areas, rear camera does not add as much arguable leverage to choose the Z90 over the Viofo.
I would suggest to look at it another way. Have a look at Vueroid S1 4k and use it's impact parking mode. If you sacrifice the parking recording for impact detection only, this camera may be able to give it coverage that would be able to play into your vehicle use habits.
- Alex
After spending countless hours watching various YouTube reviews, comparisons, and reading through detailed threads here on Dashcamtalk, I finally decided to go with dual-camera system.
My final choice:
  • Camera: VIOFO A329S 2CH (really excited to test that 4K @ 60fps!)
  • Power: VIOFO BP100 LiFePO4 Battery Pack (hardwired)
To ensure a completely seamless, stealthy, and safe installation, I chose not to do it myself and handed the car over to a professional car electronics service.
They did a fantastic job hiding all the wiring, routing the rear camera cable, and securely mounting the BP100 battery pack under the passenger seat. The professional installation cost me roughly $200 USD. In my opinion, it was worth every penny for the peace of mind and clean look.
Now it's time to test out the video quality, SSD recording stability, and dial in my parking mode settings.
