Difference between coring and denoise
Fried
Italy
Someone could explain me the difference between these two parameters, cause both are used to get more sharpness but I trying to understand eventually difference between them...
denoise
Code:
#t ia2 -adj tidx [ev_idx][nf_idx][shutter_idx]", "-1 disable"
#looks like the values are between 0-16383 (0x0000-0x3FFF)
#If you want to set noise reduction value to 2048 just remove the hash key from the row below and for all the resolutions you will have sharpness as craze
#t ia2 -adj tidx -1 2048 -1
and
coring
Code:
#disable sharpening. coring should contain only 256x10
t is2 -shp mode 0
t is2 -shp cor d:\coring.txt
S Yi Action Camera 15
D Yi Action Camera 5
