...but it "should be" a feature (with corresponding sensor) not a bug, many camera manufacturer build now lenses without a filter for UV andIR (against artifacts and moire effect) before the sensor, it gives more sharpness and better resolution. That is more important for the users and in Raw photos you can renounce on that filters because you can correct by software (for jpg it is better to have one) and in videos the lack of filter "should" have no affect!...I have a 23L version.
L versions, as described elsewhere in this forum, do not have a IR filter (the other versions do).
There are differences in still pictures and video, especially in pictures taken in front of the sun.
Could you please take and share some pictures of the same scene with your cams 22 and 22L, possibly in front of the sun or with sunlight coming from the front side, in order to compare?
To become a version without L you might have to buy from a shop with old stocks.
Not all people owning a L version has that problems sawn in another thread: https://dashcamtalk.com/forum/threads/z23l-revision-problems.13488/
I presume it depends on sunlight direction and air temperature.now I see the reason of this problem.
Filters, I doubt, lenses replacement, maybe.Are there any solutions? Maybe filters or replacement lens?
Difference between coring and denoise | Yi Action Camera | 0 | ||
D | Hardware Differences | Yi Action Camera | 5 |
Similar threads |
